frame rate hack on the HVX202 beyond 50I
#1 Allyn Laing
Allyn Laing
Posted 22 January 2008 - 07:26 PM
HI,
Using the frame rate hack as users of the Panasonic HVX202 & 200 have found it is possible to utilize the software to access the frame rate variables. We have successfully been able to move around the frame rates from 2 - 50fps, but we are wanting to go above 50.
Has anyone been able to move beyond the 50 with the frame rate utility hack.
The HVX-200 and the HVX-202 are the same body with different software/firmware right?
Any advice is very welcome
Thankyou
Al
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 22 January 2008 - 08:00 PM
50 is the maximum for PAL HVX cameras
If you had an NTSC model, 60 would be your max.
#3 Thomas James
Thomas James
  • 844 posts
Posted 23 January 2008 - 04:34 AM
In america we have 120 hertz televisions that can effectively double any frame rate.
#4 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 23 January 2008 - 08:27 AM
No they don't.
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 23 January 2008 - 01:15 PM
A TV can't change the frame rate of its source...last time I checked.
#6 Allyn Laing
Allyn Laing
Posted 23 January 2008 - 06:56 PM
When I save a specific scene file to a SD card, then load it into my computer to do a text edit, it has written above 'HVX-200' Ver. 1.00 which prompts me to beleive these are the same bodies with different software and badging.
Also the voltage is the same in both models, DC 7.2/7.9 volts.
#7 dan brockett
dan brockett
  • 66 posts
Posted 25 January 2008 - 07:49 PM
PAL HVXs actually have different hardware inside (I believe it's the crystal is different and some other little things). You cannot go above 50fps on a PAL HVX. You cannot convert or manipulate an NTSC to PAL or vice-versa. That's one nicer thing the EX-1 has, it is a true global camera.
Dan
