Very wide angle lens for Leicina Special?
#1 Gabriele Turchi
Gabriele Turchi
  • 26 posts
  • Colorist
Posted 23 January 2008 - 09:11 PM
Hi!
I just got my 1st Leicina Special and it seems fantastic!!!...
I have the 6-66 and the Cinegon 10mm Lens,
I was wondering if exist any very wide angle lens that i can fit on the Leicia Special (i mean wider than the 6mm...)
Thanks to everyone
Best regards
G
#2 jacob thomas
jacob thomas
  • 178 posts
Posted 24 January 2008 - 02:44 PM
Hi!
Thanks to everyone
Best regards
G
Do a forum search there is a thread where the lovable Santo describes his use of a century wide angle adapter on the 10mm cinegon.
IIRC the may be a wide angle adapter designed to go with the 16mm c-mount version of the Schneider Cinegon 10mm lens but perhaps I am confusing it with the Switar one.
Edited by jacob thomas, 24 January 2008 - 02:44 PM.
#3 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 24 January 2008 - 03:46 PM
Hi!
Thanks to everyone
Best regards
G
that is a C mount lens port, right? Check around ebay and such for wide angle C mounts. you can also, purchase/rent a C-mount to PL adapter and use any number of modern wide angle lenses out there. How is the registration and overall image quality? Been curious about these cameras for a while.
#4 Gabriele Turchi
Gabriele Turchi
  • 26 posts
  • Colorist
Posted 24 January 2008 - 04:03 PM
Thanks!
mmm....so the only way is to use a wide angle dapter?
No way to find a 4mm or 3mm lens?
Thanks!
G
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 24 January 2008 - 04:14 PM
How about Leica M?
#6 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 24 January 2008 - 06:22 PM
Hi!
I guess there isn't any wider lens than the 6-66 for the Special
I tried the century 0.55 adapter on the Cinegon 10mm. I had rather soft results, maybe because I never hit the right focuspoint. Since it is a diopter you do the focus in the macro-range of the lens and that's pretty hard to focus without groundglass.
You could try the Schneider UWL III Adapter on the 6-66 which should give around 3.5mm, but again it's a diopter that uses the macro setting of the lens, hard to get in focus. A thing that could work is to shoot tests and make marks beside the focusring.
cheers, Bernhard
#7 Gabriele Turchi
Gabriele Turchi
  • 26 posts
  • Colorist
Posted 24 January 2008 - 08:04 PM
cheers, Bernhard
Thanks Bernard,
i'll try to find the UWL III Adapter...
For Chris:
Mmm actually i think that does not exist any modern C mount lens wide enough for the super 8 format...the super 8 format is quite smaller than 35mm(4 times)....so for example using a 10mm lens made for 35mm it's like using a 40mm lens...(after mounted in the s8 camera...)
Am I wrong?.....i mean,ithin that only a wide angle lens made for super 8 could be a wide angle lens in the super 8 format...right?
Apologies if i am wrong..
Cheers
G
#8 itzi ari
itzi ari
  • 2 posts
  • Monterrey Mexico
Posted 31 August 2009 - 07:49 PM
Thanks Bernard,
I am wondering if you did try the UWL III...?
kind regards
Robert
#9 itzi ari
itzi ari
  • 2 posts
  • Monterrey Mexico
Posted 01 September 2009 - 05:17 PM
I tested UWL III and it works very nice...
