Fuji Vivid 160 & Snow
9 replies to this topic
#1 Matt Irwin
Matt Irwin
  • 389 posts
Posted 07 February 2008 - 02:58 PM
I'm shooting an action short soon on super35, finishing to D5 (for now). It's all day exteriors in an alpine setting-- under tree cover, as well as on top of a barron hill with snow all around. This will most likely be in sunny/ cloudless weather.
The director and I are looking for a hi-con, cold look overall and he really wants red to pop in a few scenes (blood on snow). I'm trying to do as much of this on the negative as I can prior to telecine because there is a possibility of a photochemical release print down the road.
I'm planning on testing Vivid 160 at the location or similar setting with an 85, 81EF, and no correction filter.
What I'd like to get an idea of prior to testing is how much latitude to expect from this stock-- how many stops over and under key can I expect to hold full detail, and where does information burn out or disappear into shadow? I've got action in front of trees/foliage, as well as wide landscapes and talent haloed with sunlight.
Any considerations for shooting this hi-con stock in snow? Any other quirks or unique characteristics to V160? I'm used to shooting lower contrast films like Eterna 250 & 400, and Kodak '18.
#2 Stephen Murphy
Stephen Murphy
Posted 07 February 2008 - 05:55 PM
Matt,
I've used the 160 Vivid quite a bit recently but always pushed it for extra contrast and saturation. For my taste it got a little too contrasty with a one stop push but the saturation was beautiful. Personally i might use a light low con the next time i push it.
Although it is higher in contrast and saturation then most other negative stocks it isn't as contrasty/saturated as a reversal film so you wont need to worry about loosing detail in your whites too quickly.
Hope this helps,
S
#3 Matt Irwin
Matt Irwin
  • 389 posts
Posted 08 February 2008 - 12:07 AM
Matt,
Hope this helps,
S
Thanks Stephen, good info.
I'll try a short load with a low con and push when we test. You think a #1 or 1/2?
#4 David Mullen ASC
  • 20073 posts
Posted 08 February 2008 - 12:50 AM
An idea I've always wanted to try was to shoot tungsten-balanced stock outdoors uncorrected for a cool look, but use a Color Enhancer filter to make the reds saturated. This may be a chance to test out that trick...
#5 Dalton Swift
Dalton Swift
  • 19 posts
Posted 08 February 2008 - 01:08 AM
How exactly does that give a "cool" look?
#6 Matt Irwin
Matt Irwin
  • 389 posts
Posted 08 February 2008 - 01:19 AM
Good idea! That could actually work very well for this project... If I try it, I'll scan and post the results.
Shooting tungsten-balanced film in daylight without an 85 (or other) correction filter will result in an overall blue cast to the image (aka "cool") because daylight is blue (5600K or more) when compared to warmer tungsten light (3200K).
#7 Stephen Murphy
Stephen Murphy
Posted 08 February 2008 - 05:28 AM
Test a 1/2 and see what you think - I'd love to see the results myself:) Or you could flash, or just use a bit more fill. Please do let us all know how you got on.
S
#8 Larry Miles
Larry Miles
  • 27 posts
Posted 25 July 2011 - 10:02 PM
Mr. Murphy,
I realize that this thread is a few years old, but do you have any links to the Vivid 160 pushed a stop that you could post?
#9 Stephen Murphy
Stephen Murphy
Posted 31 July 2011 - 01:29 PM
Mr. Murphy,
Hi Larry - you can look at
View on Vimeo to give you an idea. The online version doesn't really do it justice but its a useful starting point.
#10 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 20 August 2011 - 08:53 PM
stephen,
how did you shoot the flames during the title sequence at the beginning?
