wall of lights
11 replies to this topic
#1 Matt Garrett
Matt Garrett
  • 39 posts
Posted 12 February 2008 - 03:34 PM
I am starting on a budget for a music video and the band is asking for the typical "wall of lights" behind them.
ala
http://myspacetv.com...ideoid=10337648
and
http://www.redcamser...age3/page3.html
What lights are typically used for this sort of thing and what boards to people prefer to use for the strobing?
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 12 February 2008 - 04:06 PM
Hi Matt,
I assume these are PARs. But we could ask the gaffer of this shoot what they used. His name is Alex Haspel and he is on the boards here.
Cheers, Dave
#3 Kieran Scannell
Kieran Scannell
  • 339 posts
  • Netherlands/Ireland
Posted 12 February 2008 - 04:24 PM
Kevin Zanit shot a band with the look your looking for ( last year i think ) anyway it looked really good.
He posted in detail how he did it, search the forum or PM him he can help you out.
Kieran.
#4 timHealy
timHealy
  • 1262 posts
Posted 12 February 2008 - 04:52 PM
Hi Matt,
Cheers, Dave
I don't think you have to assume. You can see the gel frame ears on the heads.
They are 1 par can's probably rigged off of pipes and everything is blacked out behind it. Par can's are relatively cheap to rent but they are hooked up to dimmer packs. It looks as thought the lights were dimmed down to say 50 percent and some of them were bumbed up to 100 depending on what the camera sees and the rhythm of the music.
Best
Tim
#5 Matt Garrett
Matt Garrett
  • 39 posts
Posted 12 February 2008 - 04:53 PM
Thank you guys very much.
Will look into it.
#6 Sebastian Andexer
Sebastian Andexer
  • 22 posts
  • San Antonio, Texas
Posted 12 February 2008 - 06:07 PM
Those are either two dinos or super dinos, im not too sure. Maxis are pretty popular as well (alot smaller and easier to use than dinos). The nice part is that punch lights are pretty cheap to rent.
#7 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 12 February 2008 - 08:18 PM
The lamps in the first link definitely are parcans, most likely Par64s, which are 1k lamps.
The second has two 30 lamp dinos. Which is basically a lamp that consists of 30x 1k par lamps.
#8 Ken Minehan
Ken Minehan
  • 168 posts
  • Singapore
Posted 12 February 2008 - 09:33 PM
When you have SO many lights behind, pointing directly at the camera, how do you control the incredible amount of flare that you would get. A little bit of flare would be nice i assume, but with so many lights, is there anything you can do ?
regards
ken minehan
#9 timHealy
timHealy
  • 1262 posts
Posted 13 February 2008 - 11:05 AM
regards
ken minehan
You can only use good or newer lenses with better antihalation coatings than what older lenses would have.
You can flag off the lights but as they are in your shot, so it kind of becomes it is what it is.
Since the pars are pointed straight at the camera you could use dimmer packs and dim them all down. They don't have to be 100 percent.
Different bulbs (Very narrow, frosted narrow, medium and wide) may give a different look but you may have to experiment with what it looks like when your are slightly off angle to see what you like best.
Tim
#10 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 13 February 2008 - 04:13 PM
Thanks for the complement Kieran,
The thread is:
http://www.cinematog...mp;#entry193138
I would agree, those look like PAR globes of some sort, I would bet the source there was a 36 light Dino, I think it is 6 globes tall by 6 wide in the photo (6*6=36)
I think a lot of the trick to shooting into the sources is good lenses keeping the flare under control and also making sure your talent really pops to begin with because when the lights behind them start blooming you can very easily loose the foreground.
Kevin Zanit
#11 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 02 April 2008 - 03:17 AM
ala
and
hi Matt,
as David already said, i was gaffing the second video.
people here are spot on with their estimations, yes,
we used 2 dinos, which (at least around here) consist of 30 par64 globes each.
and if i remember correctly, it was cp62 ones.
fast strobing was not required, we had them on dimmerpacks.
but the way we had to do it has been seen a million times, you better hold onto kevins video ;)
best of luck,
alex
Edited by Alex Haspel, 02 April 2008 - 03:21 AM.
#12 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 02 April 2008 - 09:29 AM
I made DIY blinder for a project with a bunch of cheap surface mount edison sockets (like ceiling mount fixtures use) filled with clearance priced 75 watt PAR38's. Everything was mounted on a blacked out Hollywood (plywood) flat. Obviously it didn't have the "punch" of a real Dino but it was for a miniDV music video and looked just fine on camera.
