stripes on dress on 16mm
#1 tommy holman
tommy holman
  • 19 posts
  • 2nd Assistant Camera
  • London, UK
Posted 25 February 2008 - 01:35 PM
Hey,
I am about to shoot a short film on 16mm, using an Arri-SR3, one of the actresses in the film has a dress on with vertical stripes going down the dress, the stripes are around 2mm wide and there is about a 1cm gap between each stripe, will that be a problem if shooting on 16mm film?
As i have heard before that sometimes stripes on film can cause a problem if the film does not hit the stripes in exactly the same place and it can seem like the stripes are moving around, is this correct?
Any help would be great, thanks for your time,
Tommy Holman
#2 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 25 February 2008 - 02:33 PM
Hey,
Tommy Holman
On 'Film' they will be fine.. once transferred to 'VIDEO' they will be a problem!
#3 tommy holman
tommy holman
  • 19 posts
  • London, UK
Posted 25 February 2008 - 02:37 PM
We will be getting it telecined to digi beta, will that cause a problem? and why? also what is the best way to resolve the issue, apart from getting rid of the dress! thanks again.
#4 John Holland
John Holland
  • 2273 posts
  • London England
Posted 25 February 2008 - 02:45 PM
I think you shouldnt worry this problem happens on video but with much smaller stripes like in a Pin Stripe suit .
#5 Amin Khan
Amin Khan
  • 13 posts
Posted 25 February 2008 - 02:53 PM
its called the moire effect and occurs with digital scanning as opposed to analogue film. I think if there is an issue when you digitize the film im pretty sure it can be overcome.
here is an explanation
http://en.wikipedia..../Moiré_pattern
#6 timHealy
timHealy
  • 1262 posts
Some striped clothing causes a moire pattern and this only happens in the video world. It never happens on film(as far as I know). You will however see it on things shot in film and transferred to video.
It happens when the pattern on clothing and other things, interferes with the interlaced lines on video.
The same piece of clothing may not cause it on close up but may cause it on wider shots as the detail gets finer and finer.
If you want to be sure you don't get it, then change the outfit. If you can't change to outfit you may want to do a test. According to Murphy's law if you don't do a test, then you will surely get it.
Actually with the latest progressive video formats, I wonder if this is less likely to happen. But one cannot be sure with a test.
But without actually seeing the clothing you are planning to shoot, no one here can offer much more advice.
Good luck
Tim
Edited by timHealy, 25 February 2008 - 02:57 PM.
