35mm lenses on super16
13 replies to this topic
#1 tommy holman
tommy holman
  • 19 posts
  • 2nd Assistant Camera
  • London, UK
Posted 25 February 2008 - 01:45 PM
Hey,
Im AC'ing a short coming up which is using Zeiss superspeed 35mm lenses, but shooting on 16mm, how does that effect my depth of field?
I know i am still shooting the same format, so my COfC will stay the same right? but 35mm lenses have a shallower depth of field, so will it reduce my depth of field, from say if i was using 16mm lenses? and if so, how can i get depth of field tables for this reduction in depth of field?
any help would be great, thanks for your time,
Tommy Holman
#2 Chris Keth
Posted 25 February 2008 - 01:56 PM
It doesn't affect it at all. Proceed as you would if you had lenses designed for 16mm.
#3 tommy holman
tommy holman
  • 19 posts
  • London, UK
Posted 25 February 2008 - 02:33 PM
Thanks Chris, thats what i thought i will carry on as if i was shooting with 16mm lenses.
#4 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 25 February 2008 - 03:04 PM
Tommy Holman
No, they don't. The depth of field is the same. It's the format you shoot on that makes the difference, not the lenses.
#5 Rory Hanrahan
Rory Hanrahan
  • 175 posts
  • NYC
Posted 26 February 2008 - 09:25 AM
Just keep in mind that there is an effective change in focal length (like putting a 35mm SLR lens on a smaller format DSLR). The lens is the lens is the lens, but your field-of-view will change based on your format.
#6 tommy holman
tommy holman
  • 19 posts
  • London, UK
Posted 26 February 2008 - 12:10 PM
great thanks for all your help with the subject, tommy
#7 Tristan Noelle
Tristan Noelle
  • 61 posts
  • North Hollywood, CA
Posted 26 February 2008 - 12:49 PM
An instructor once told me to not chance using a set of PL mount Zeiss primes made for 35mm on a Super16 SR2 because the rear element could interfere with the shutter. Is that a problem anyone has run into?
#8 John Sprung
John Sprung
  • 4635 posts
Posted 26 February 2008 - 05:49 PM
No, if anything it would be the other way. The 35 aperture is wider, so the mirror at 45 degrees to the film plane would have to extend farther from that plane at the optical axis. If you're worried, test it. With the camera empty, inch the shutter open, mount the lens, focus to infinity, and very gently inch it while looking thru the aperture.
The other caveat using 35 format lenses on 16 is that the wide angles, say 18 mm and wider, will have a lot of design compromises that make them not as sharp and flat as the same focal length designed only to cover 16mm.
#9 Tristan Noelle
Tristan Noelle
  • 61 posts
Posted 27 February 2008 - 09:00 AM
Thanks for the information John. I'll give that test a try.
#10 Chris Keth
Posted 27 February 2008 - 08:59 PM
Do it VERY gingerly and disconnect the battery when you do it. You don't want any chance of accidentally phasing or running the camera with something in the way of the mirror. That would be a very expensive mistake with, I'm betting, a really sickening noise associated. :o :blink:
#11 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 28 February 2008 - 10:33 PM
Hi- I hate to be the one to point this out, but if I put a 50mm lens on an SR3 then just exactly what focal length does it effectively become?
and yes, I already know the answer.... ;)
#12 Chris Keth
Posted 29 February 2008 - 12:18 AM
I don't like it when people refer to it as an effective change in focal length, either. <_<
It's a change in field of view. Nothing more.
#13 Adrian Sierkowski
  • 7373 posts
Posted 29 February 2008 - 12:23 AM
50mm. So far as I know the lens isn't going to grow. . .
#14 Rory Hanrahan
Rory Hanrahan
  • 175 posts
  • NYC
Posted 29 February 2008 - 09:18 AM
Chris -- You're absolutely right, and while I was trying to convey that point as lightly as possible, I have also been waiting for the captive bolt air-gun to knock in my doorknob and cry: "Nay, you silly bastard, nay"?
