Running an Arri 2B
#1 Eric Black
Eric Black
  • 20 posts
Posted 07 March 2008 - 09:21 PM
Hello everyone, I have purchased an Arri 2B to do some MOS work. I have worked in 16 and 35 and have experience with a few cameras.
The only problem is .... I can't figure out how to run the Arri 2B!
It has a crystal-sync flatbase, but I am not seeing any knobs or switches to get this thing going. Its quite an embarassing problem as I have used film before, with no problems. How do I get it running?? The online 2c manual is no help, as the diagrams are poorly copied and do not show any detail.
Any help would be appreciated. I have batteries hooked up to the sync motor on the flatbase.
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 07 March 2008 - 09:46 PM
What flat base do you have? There are quite a number of different ones. There is the Tobin Crystal sync flat base. The Cinematography Electronics crystal sync flat base. There are a number of flat bases where you use the ARRI motor or a crystal sync motor like the Thoma motor. If you could post a picture of what flat base/motor combination you have, we can probably tell you how to turn the motor on.
If you are using a flat base that incorporates the ARRI constant speed motor, that motor has a switch mounted on it, right where it mounts to the base. It is a toggle switch.
Best,
-Tim
#3 Eric Black
Eric Black
  • 20 posts
Posted 08 March 2008 - 04:15 PM
Picture of the motor
Area circled in RED:
This appears to be a switch or something, but it doesn't move at all, it won't go up or down or anything, and is a solid piece.
Area circled in BLUE:
This is a knob that turns around, but doesn't do much more than that.
#4 Eric Black
Eric Black
  • 20 posts
Posted 08 March 2008 - 04:18 PM
The ARRI 2B has a Tobin Crystal TXM9-S
and a Tobin Milliframe Controller TMC-55Aa
#5 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 08 March 2008 - 05:15 PM
Eric,
You've got an odd duck there. If your numbers are correct, that is a very early Tobin crystal motor set up, something that got put together and could be used on a number of different cameras. From Clive's web site:
"There was also an unrelated series, TXM-9S, which shared the circuit board but with different parts installed, mounted in a rectangular box, used with modified Arri 35mm 2A-2B-2C and 16-S and 16-M cameras. We have been unable to find any existing computer files on these."
I would suggest taking very clear pictures of the whole base, from all four sides, and the wiring between the base and the Milliframe controller, and giving Clive Tobin a call on Monday (509-922-7841). He may be able to tell you how to make it work. But it may be missing some parts.
Best,
-Tim
#6 Henri Titchen
Henri Titchen
  • 125 posts
Posted 08 March 2008 - 06:29 PM
I have a base that looks very very similar. Mine is a genuine Arriflex AC Sync base (as are used in blimps). It has a frame counter etc on mine. The pin you have circled in red is not a switch. It is just an alignment pin onto which the switch box would originally slide, it serves a mechanical purpose, not electrical. There is a photo of one of these bases at Nathans site:
http://www.owyheesou...at-base-mot.jpg
You can just see the pin that you have circled red on the above photo.
It is highly likley that someone has retro-fitted another motor onto your base. It would pay to get an electrical/electronic guru to see if they can figure out the wiring/voltage requirements.
Henry.
#7 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 17 March 2008 - 10:06 PM
So, you decided to sell it on eBay already. That was quick.
Arriflex IIB package
-Tim
