Mixed lighting situation
10 replies to this topic
#1 Mike Green
Mike Green
  • 8 posts
Posted 08 March 2008 - 11:37 PM
I am shooting a 30 second commercial for a class project. I am using a Panavision G2 35mm with Kodak EXR 500T 5298 film stock (might be able to use 250D but not sure yet).
I am shooting on the top floor of a library. The main area is a large square room with a very high ceiling (30ft maybe) and large windows and is set up for reading. It baths the area in natural sunlight although it is not direct until late afternoon. I should be done before i get any direct light. I have checked the light through out the day and am reading consistantly at 4.0. in the main area.
The high ceiling in the main area transitions to a low ceiling on all four sides that stretches outward. The low ceiling areas are filled with rows and rows of book shelves and are lit using florescent light fixtures.
Some of the action will be in the main area and the rest in the low ceiling areas with the fluorescent lights. Naturally there is a mixture of both light so i am trying to figure out how to shoot in this mixed environment. its my understanding that if i correct for the daylight (85 filter) i will get green off the lights. If I don't correct for daylight I will get a blew hue from the daylight.
So i would like some assistance or thoughts from anyone with a similar experience. feel free to add anything it will only help me learn.
thx!
Posted 09 March 2008 - 12:29 AM
First of all, MikeG, you need to go to My Controls and edit your Display Name to a first and last real name as per the forum rules. This is what you should have seen when you registered:
Forum Terms & Rules
READ THIS - IT'S NOT LONG
You must register using your REAL NAME. That means your first name, a space, then your last name. If you don't use your real name, or you register with a name that looks like your real name but we find out is not your real name, your account will be permanently disabled.
After you create your account, you MUST create a signature that will be automatically appended to your posts. The simplest signature will be your name, and we encourage you to add a link to your web site or IMDB profile if you have one.
Cool White fluorescents are a little warmer than daylight (4100 to 4800K instead of 5500K) and greener. If you don't correct for them, you get a sickly greenish cast from them depending on how dominant the effect is. If you do correct for them, your daylight goes the opposite of green, which is pink (magenta).
Your best bet is to turn them off and use the window light plus any daylight lighting you can add if necessary (HMI's or daylight fluorescent like Kino 55 tubes in Kinoflos) or replace the tubes in the ceiling with something close to daylight with as much green in them (Kino 55 tubes or Chroma 50's, for example.)
Other option is to add green gel (Plus Green) to all the windows and other sources to match the Cool Whites, then time the green out in post, or add magenta gel (Minus Green) to all the Cool White fixtures.
Or live with a little greenishness...
#3 Mike Panczenko
Mike Panczenko
  • 324 posts
  • 2nd Assistant Camera
  • Philadelphia, USA
Posted 09 March 2008 - 01:46 AM
Hasn't 5298 been discontinued for close to 4 years now? I would absolutely get a clip test done to ensure the safety of using the stock.
#4 Mike Green
Mike Green
  • 8 posts
Posted 09 March 2008 - 03:03 AM
ok thx! unfortunately they will not allow me to shut off the lights in the library. nor will they allow me to plug any lights into the building outlets. apparently someone blew fuses in the place previously and the dean put a stop to it. I am looking into using battery powered HMI's. I may have to live with the greenish lights. im not sure the status of the film stock. It was given to me free to use by the department. I might be able to shoot on a lower floor that is not bathed in daylight so that may be an option as well.
thx again!
#5 Freya Black
Freya Black
  • 4164 posts
Posted 09 March 2008 - 10:00 AM
thx again!
I think your situation is preety intresting! :)
Can your film be an advert for anything or do you have a set brief?
Perhaps it could be an advert for daylight balanced flo tubes, and how they can help you cope with S.A.D. etc.
Or perhaps it could be an advert for some kind of security system. Metal detectors for instance. That way you could make the most of the green hue and with a bit of smoke and someone in a tenchcoat with a fake gun, you could go for a matrix kind of thing and warn everyone on the dangers of terrorists (who are hiding everywhere these days) and students with shot guns who wear too much black and listen to loud music.
Depends how green the green is I guess.
It seems to me that if you had a really huge piece of cardboard you might be able to flag off the light from the tubes. This would probably mean unfeasable large pieces of cardboard tho. ;)
You might want to take a video camera with you or a digital still camera and set it on tungsten to see what the colours might look like.
I don't think your film is worth getting clip tested as I'm preety certain it will fail. However they might be able to sort it a bit in telecine. It seems like this is a bit of a learning shoot anyway so maybe old film is not so bad. :) The EXR series was nice when they made it too, so it should be fun to try. I'd try and expose it at 250ASA to overcome the base fog or at least to rate it at 320ASA. It might help compensate if the films gone a bit more grainy too.
Could you maybe get to turn off some of the lights nearer the window where things are lit with sunlight anyway? If you get in early enough before other students, they may not even notice those lights are off!
love
Freya
#6 Joseph Zizzo
Joseph Zizzo
  • 78 posts
  • new york
Posted 09 March 2008 - 11:03 AM
hi mike,
i know you said it is a student project you're doing, but if there is any chance at all of using a little more current film stock, there are a few that are very good in mixed lighting situations.
fuji reala 500D is the best in mixed lighting, you won't have to gel lights or windows or change flourescent tubes. it is daylight balanced, and very forgiving in the shadows, so it would kind of solve all of your problems. you could then concentrate on the storytelling.
oh, and its a bit cheaper than kodak.
good luck, and have fun!
#7 Joseph Zizzo
Joseph Zizzo
  • 78 posts
  • new york
Posted 09 March 2008 - 11:12 AM
oh, and i meant to say, i thought freya made a good point about turning off the lights nearest the talent.
you could just turn the flouro tube a bit, if you can reach it, just until it shuts off. as freya said, probably no one will even notice. then, if you are forced to use the '98, you will avoid that nasty green in fill side of faces. even if you are using a newr stock, you might want to do that if the window light is better on people than the overhead flourescents. (it usually is.)
what school are you in, anyway?
#8 Mike Green
Mike Green
  • 8 posts
Posted 09 March 2008 - 12:07 PM
hi al,
thx for the great info. I will check on the film stock and see if it is available. I am in the film program at UNLV in Las Vegas. We have some great instructors and a small class size (around 600 students i think). If you have any questions about the program based on my experience please feel to ask. I am an older student (39) who went back to school for a degree in computer science, then history, and finally film. I love it!
anyway thx for the great help. Any suggestions are appreciated!
Mike
#9 David Mullen ASC
Posted 09 March 2008 - 12:21 PM
My advice is to find a way to plug lights into the wall, even if it means running a cord from the hallway. There is nothing more useless than battery-powered lights (other than maybe an eyelight) for shooting any scene that will take time.
Or get a new location, one that will let you turn off the overheads and let you plug into the wall. Unless this is a documentary, these are silly restrictions to have to put up with. A Kinoflo is not going to trip a household circuit.
#10 Joseph Zizzo
Joseph Zizzo
  • 78 posts
  • new york
Posted 10 March 2008 - 08:28 PM
mike,
david makes, not surprisingly, a good point - a reality check from the voice of experience! can you move to a more friendly location? that will make your life a lot easier...
#11 Mike Green
Mike Green
  • 8 posts
Posted 10 March 2008 - 09:36 PM
Hey all,
Today I scouted out a new location with the help of my professor. The staff at the new location were way more accommodating. I am just waiting on a confirmation from the head of the facility. I got the impression that it would not be a problem as other student had used it before. It is a mixed lighting situation as well however the windows are no where near as large and they have blinds so i can control the light better. I should be able to use HMI's as well. I also have access a fisher dolly (10) for it so I am hoping to do some cool moving shots.
thx for the input!
Mike
