Zeiss mark 1 superspeed filter size
16 replies to this topic
#1 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 10 March 2008 - 07:33 AM
Does anyone know the thread size for the front end of the 12 and 9.5mm Zeiss Mark 1 superspeeds?
#2 Brian Drysdale
  • 5194 posts
Posted 10 March 2008 - 10:02 AM
From memory, you use a clip on matte box, there isn't a thread for round screw in filters.
#3 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 10 March 2008 - 10:14 AM
Thanks Brian but I wouldnt be asking if there wasnt! The 25mm and 16mm have a 58mm thread and the lenses are 62mm round.
The 9.5 and 12mm have a 70mm diameter and it would be easy to think the thread size is going to be 66mm and it might very well be. However Id like to check before ordering a step up ring.
#4 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 10 March 2008 - 02:22 PM
A 67mm thread is more likely since that is a fairly standard size.
& I think that was the filter size on the 35mm MkI Zeiss high speeds.
#5 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 10 March 2008 - 04:17 PM
Thanks Leo! Does anyone else know for sure?
#6 lluis
lluis
  • 63 posts
Posted 14 March 2008 - 07:39 AM
These lenses don't have front thread. The external diameter is 70mm. You will need clip-on system rings...
#7 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 14 March 2008 - 07:45 AM
Sorry lluis unless there has been some misunderstanding here but they do.
#8 lluis
lluis
  • 63 posts
Posted 14 March 2008 - 07:58 AM
Mine don't have it.
Check the pictures http://www.visualpro...;Cat3=25#bigPic
#9 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 14 March 2008 - 08:27 AM
Mine don't have it.
Those lenses have been upgraded with 80mm fronts in order to make them uniform. The original Lenses had none. I dont know whether the 80mm front rings will undo? Why did you say the external diameter was 70mm when its 80mm on the attached front rings? If you took the 80mm front rings from 9.5mm and 12mm lenses then you would have a 70mm diameter lens and probably a 67mm thread size. ALTHOUGH I'm unsure of the thread size and is why I asked here.
Edited by Mark Williams, 14 March 2008 - 08:28 AM.
#10 lluis
lluis
  • 63 posts
Posted 14 March 2008 - 09:29 AM
Mark: I come from very far from Visual Products... I wrote the link because I haved to double check if these wide angles have or don't have front threads: mine lenses, the similar from the pictures, don't have it. As I wrote, the original front diameter is 70mm. The others 16 /25mm mk1's have a 58mm internal thread. All the best,
#11 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 14 March 2008 - 10:33 AM
Hi lluis The reason I assume you can add a filter is because I have tried one on the 25mm and 16mm and can see a thread on the 9.5mm and the 12mm. Does your 9.5mm lens look like this?
#12 Brian Drysdale
  • 5194 posts
Posted 14 March 2008 - 11:42 AM
I no longer have my MK!s to check, but that thread in the picture looks like it's designed for screwing in the front element retaining ring rather than screw mounting filters. That's not to say you couldn't screw a filter on, but it looks rather like there only a couple of threads to hold it.
#13 Brian Drysdale
  • 5194 posts
Accidental double post
Edited by Brian Drysdale, 14 March 2008 - 11:44 AM.
#14 lluis
lluis
  • 63 posts
Posted 14 March 2008 - 12:49 PM
Mine is with the front completely flat, but I am sure that you can't thread anything in front of this (picture) lens. These lenses cover super 16, condition to putting a 70mm slip-on external housing, if not will vignette...
#15 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 14 March 2008 - 01:09 PM
I dont know about that But yes they do cover super 16mm so hopefully will be alright in standard 16 with an anamorphic lens attached.
#16 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 14 March 2008 - 01:18 PM
Brian You may be right I cant be sure. Regarding the 25mm and 16mm thoughI have already had a 58mm filter on them. If not I will just have to settle for using the Anamorphic lens on my EX-1 for a 1:66 frame or My krasnogorsk 3 for the wide angles. :)
#17 Carl Nenzen Loven
Carl Nenzen Loven
  • 172 posts
  • San Francisco
Posted 10 October 2017 - 03:51 PM
Brian You may be right I cant be sure. Regarding the 25mm and 16mm thoughI have already had a 58mm filter on them. If not I will just have to settle for using the Anamorphic lens on my EX-1 for a 1:66 frame or My krasnogorsk 3 for the wide angles. smile.gif
Did you figure out the size for the front?
C
