T and I button on camera body
#1 Audrius
Audrius
  • 5 posts
Posted 16 March 2008 - 04:22 PM
Hello ewerybody,
What does mean button with two positions marked by letters T @ I on camera (Bolex H16 reflex ) body.
Audrius
#2 Don Brown
Don Brown
  • 89 posts
  • Sound Department
  • The Original Boston UK
Posted 17 March 2008 - 05:47 AM
Hello ewerybody,
Audrius
Hi Audrius
The T stands for Time and the I is Instantaneous used when doing Single Frame shots the time position is used in poor lighting conditions
Regards
Don
#3 David Schwartz
David Schwartz
  • 2 posts
  • Steadicam Operator
  • Philadelphia, PA
Posted 21 March 2008 - 08:26 AM
To clarify that a bit, the T and I positions control how the shutter operates during single frame filming.
In the I position, the shutter opens and closes instantaneously when you move the side release to the P position.
In the T position, the shutter will stay open as long as you hold the side release in the P position and closes when you let it go.
As Don said, it's useful in poor lighting conditions, and it also allows animators to work at smaller apertures for greater depth of field without having to light their miniature sets to levels that will start melting everything.
It's also great for achieving streaky/blurry effects, especially with night exteriors.
#4 Sean McHenry
Sean McHenry
  • 175 posts
  • Hilliard, Ohio
Posted 21 July 2008 - 03:37 PM
Like the "Bulb" on older 35mm still cameras. The "T" setting in single frame mode that is. Stayed open as long as you squeezed the bulb which was like an ear syringe.
Sean
