test red f23 ex1
13 replies to this topic
#1 hill jack
hill jack
  • 1 posts
Posted 21 March 2008 - 09:25 AM
http://provideocoali...as_ex1_f23_red/
no idea if these people can be trusted, but they seem to be quite knowledgable
#2 Brian Drysdale
  • 5195 posts
Posted 21 March 2008 - 09:45 AM
Adam Wilt is a well known reviewer. There were comments on RedUser about how rushed the testing was and not quite his usual standard. However, he is buying a RED, so I guess (as he says) you can regard his comments on the RED as being on a moving target.
#3 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 21 March 2008 - 10:20 AM
To be honest I didn't find this test very useful. For instance I would have put a Master Prime on the Red, so that the lens quality on both the Red and the F23 would have been the same, thereby taking the lens out of the equation. I'm sure other people can chime in about the post route (especially the scaling) that was applied to the images.
#4 Zakaree Sandberg
Zakaree Sandberg
  • 26 posts
  • orange county,ca
Posted 21 March 2008 - 03:12 PM
agreed. if your going to test.. have the same parameters
#5 David Mullen ASC
  • 20072 posts
Posted 21 March 2008 - 03:35 PM
Hard when comparing a camera that takes B4 HD lenses versus 35mm cine lenses, though certainly a Zeiss DigiPrime and a Zeiss Master Prime or Ultra Prime are all closer to each other than a Zeiss Super Speed. But there are limits in matching parameters.
#6 John Sprung
John Sprung
  • 4635 posts
Posted 21 March 2008 - 04:30 PM
To be honest I didn't find this test very useful. For instance I would have put a Master Prime on the Red, so that the lens quality on both the Red and the F23 would have been the same, thereby taking the lens out of the equation. ....
I'd go farther. Comparing 2/3" with 35mm isn't apples and oranges, it's apples and watermellons. Compare D-20 with Red, and use the same lenses -- not just make and model, the exact same units.
#7 DJ Joofa
DJ Joofa
  • 149 posts
Posted 21 March 2008 - 05:49 PM
I would think that opposite should be true. You want the lens in the equation. Basically, you want to the test the output of Red and F23, and hence, it is very important that your input to the two systems be the same. Putting the *same* quality lens on both will not do justice to smaller sized chip of F23 if the MTF of the lens is not matched with the F23 chip. As long as that is not true, which would happen frequently in practise, because of limited MTF of lenses, you want to *normalize* the input, and hence use correspondingly *different* lenses on both cameras that provide the same level of input detail in relation to their different sensor sizes.
#8 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 21 March 2008 - 07:01 PM
I was not suggesting that he should use the exact same lens on the Red as on the F23, after all that is impossible. My point is that the Master Prime is the 35mm equivalent of the Digi Prime used on the F23. Both of these lenses feature the latest in optical and mechanical design The Superspeed he used instead is a 20 year old lens that is just not as good.
#9 DJ Joofa
DJ Joofa
  • 149 posts
Posted 21 March 2008 - 07:37 PM
I see. Makes sense. You are right.
#10 Tom Lowe
Tom Lowe
  • 1211 posts
  • somewhere worshipping Terrence Malick
Posted 22 March 2008 - 03:25 PM
The resolution tests, even if they are only in the ballpark, pretty much confirm what I have been saying for 2 years now = Red is essentially a 2K camera. You should shoot 4K and finish 2K. When you look at it that way, the camera is a remarkable value. A dream camera in many ways.
I really wonder about that test of the guy with the beard holding the chart in the garden. Why was the RED shot so incredibly soft? Any chance this was a focus issue?
#11 Zakaree Sandberg
Zakaree Sandberg
  • 26 posts
  • orange county,ca
Posted 22 March 2008 - 05:49 PM
exactly. thats what I mean.. i shouldnt have said SAME.. but equivalent
#12 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 March 2008 - 01:46 AM
As much as I adore Videofax as my friendly neighborhood rental house, it's hardly a place to conduct a test that produces firm results.
#13 Chris Kenny
Chris Kenny
  • 264 posts
Posted 24 March 2008 - 08:43 AM
We've been running around shooting stuff with Superspeeds on a Red for the last week. They're fun lenses (we've managed to get great looking shots under lighting conditions I never thought we could get away with), but not exactly the sharpest in the world.
#14 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 24 March 2008 - 09:42 AM
Hi Chris,
If they are stopped down to T2.8 the should be very sharp. One thing to bear in mind wide open is DOF is minimal, e.g on a close up of a face only one eye may be in focus. (or possibly nothing if your focus puller or colimination is slightly off)
Stephen
