Window Flares
#1 David Regan
David Regan
  • 218 posts
Posted 21 March 2008 - 04:43 PM
I was curious as ways to avoid getting a washed out image from pointing the camera directly at a window. I recently had a shoot where there were two characters in the FG and a window in the BG, and the window essentaily flared the entire image, washing out the contrast pretty badly. However I see in films all the time, situations like this, and there is none terrible flaring. Take No Country for Old Men for instance, all the blown out windows which I think looks stunning, and there is none of this low contrast issue. Any way I can safely aim my lens at a window, blown out or not, and avoid this problem?
Thanks for the help.
#2 timHealy
timHealy
  • 1262 posts
Posted 21 March 2008 - 05:06 PM
Using ND on the windows to lower the outside exposure and utilizing lighting to bring up the interior levels helps.
Best
Tim
#3 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 21 March 2008 - 05:22 PM
It depends on the lens, they all have different flare characteristics. Roger Deakins' beloved Cooke S4's are notorious for their handling of flare.
Using a lot of filters and/or a zoom lens will have the most glass to compound flare/reflection problems; an unfiltered prime with good coating will behave better under the same conditions.
#4 David Regan
David Regan
  • 218 posts
Posted 21 March 2008 - 05:30 PM
Filters and zoom lenses have the most glass and compound flare/reflection problems; a good prime with good coating will behave better under the same conditions.
Yeah I was using a prime, but it was an old Cooke Series2, and rather worn so I'm not sure about the quality of the coating.
Tim-
Your reply make sense to me, but I'm still a bit confused since some shots have blown out windows without washing out the image. Possibly just what Michael mentioned about coating?
I think the filter I had in was an 85 which probably didn't help with the flaring issue <_<
I have an upcoming shoot with a planned shot of someone sitting on a couch in front of a window, straight on, so I'm trying to avoid the past mistake.
Thanks all
#5 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 21 March 2008 - 05:34 PM
Not just the coating, but the entire construction of the lens. S4's are just really good with this.
You can try a mattebox with an angled filter stage (or just swing a matte box out slightly) to minimize filter reflections. This is really more useful for small specular highlights that can create a "ghost" reflection, but it can help with general flare also.
Edit: Oh, and shooting at higher f-stops can minimize flare also, depending on the lens.
#6 Kiarash Sadigh
Kiarash Sadigh
  • 101 posts
  • Toronto
Posted 22 March 2008 - 04:05 PM
If you can narrow your angle of view by moving the camera far back and use a longer lens, then you can manage your flares a lot better.
#7 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 23 March 2008 - 11:23 AM
Read a book about the Zone system for exposure.
Understanding the zone system will help you understand how to let the window blowout and not created a bad flare.
Either reducing the light coming into the window and/ or raising the level of the interior to closer to the exterior level will help with this issue.
#8 David Mullen ASC
  • 20068 posts
Posted 23 March 2008 - 11:35 AM
And don't use a lens prone to flaring.
Besides ND on a window, I've sometimes gotten away with putting a frame of Double Net Scrim outside the window -- it only cuts one-stop but sometimes that's enough to stop the flaring.
#9 Darryl Richard Humber
  • 143 posts
  • Grip
Posted 23 March 2008 - 02:03 PM
Most grip departments keep a "camera ready double" which is just a double net, usually 12x12 , in pristine condition for just such a shot.
