viewfinder masking
7 replies to this topic
#1 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 22 March 2008 - 06:59 PM
Namaste,
I look forward to mask the viewfinder of my XTR plus for the 2.40:1 framing. Not the viewing screen marking.
Please share your experience and the process in this regards.
With best regards,
#2 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 24 March 2008 - 09:54 AM
It can be done with scotch tape but it is not easy. I suggest having a camera technician perform this for you.
#3 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 24 March 2008 - 08:25 PM
Namaste Mitch,
Thank you very much for your suggestion. I tried to mask on the eyepiece and immediately realise that it will be a difficult task. I have yet to go through with unscrewing the viewfinder and give a try.
We dont have a qualified tech to perform this job in Kathmandu for the moment, have to send to other country which is not viable at this time, so I must have to go with masking.
Thank you very much for your input. Seek your advice as always.
with best regards,
#4 Nicole Schiller
Nicole Schiller
  • 1 posts
Posted 10 June 2008 - 02:01 AM
Namaste Deepak Bajracharya,
Do you have an email I can write to you? I found your placement on Mandy but the email does not work. It is regarding shooting a film in Nepal.
Cheers, Nicole.
#5 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 14 February 2009 - 08:01 PM
Namaste,
I have done something like this for the viewfinder masking as per the suggestion.
Firstly, tried to figure out the tentative coverage of the given aspect ratio by framing the Frame Chart and mask by the scotch tape on the viewfinder.
Secondly, figured out the tentative area by the tape, took the unexposed/developed 35mm still negative ( can find on the begining of the roll ), made a cutout size to fit onto the viewfinder and began to find the ratio by cutting on the center with the small paper knife.
Trying for the numurous time, finally came to get closer to the 2.40:1 ratio.
With best regards,
#6 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 14 February 2009 - 08:10 PM
Dont know whether it is the professional approach or not.
With best regards,
#7 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 15 February 2009 - 12:05 AM
With best regards,
Don't think it's going to work !
You need to mark up the ground glass not the viewfinder. It will just be out of focus....
You have an XTR plus ? Im afraid it's not that easy to remove the ground glass from what i remember.
jb
#8 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 17 February 2009 - 01:08 PM
Namaste,
Just out of curiousity, I already shot two full length features in such way, it worked very well for me as the frame guide line is nearly perfect enough for the composition and there is no out of focus issue.
With best regards,
