Technical Question
#1 Chris Jordan
Chris Jordan
  • 11 posts
Posted 23 March 2008 - 08:28 AM
Hello, thanks to whoever reads this and may be able to give me an answer. Being new to learning cinematography I have been going over the ACM 9th edition. This may be a stupid question, but in the formual for figuring out footcandles needed to expose a certain ASA the formual is
E=25 fsquared
over
St
In working the formual it obviously works, but can anybody tell me what the 25 represents. I have looked all over and I just can seem to figure it out.
Again, this may be a stupid question, but if anybody can give me an answer that would be great.
Posted 23 March 2008 - 11:38 AM
I don't know that formula.
I just use the old rule (for a camera running at 24 fps with a 1/48th shutter speed):
100 fc at 100 ASA = f/2.8
From that you can figure out most variations of ASA or footcandles or f-stops.
#3 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 24 March 2008 - 02:49 AM
I'm not familiar with that formula or with the terms you use (E and st).
But the relationship between f/stop, film speed and footcandles is of exactly that sort.
The film speed (ASA rating) was originally calculated in an extraordinarily complicated way based on the exposure needed to reach a density a certain amount more than the minimum density of the film, when it was processed to a certain gamma, and the moon was at a particular angle in the sky etc.
As it turns out, there is then a simple relationship betwen the film speed and exposure settings on a camera. In proportional terms, doubling the footcandles, doubling the film speed, or halving the square of the f/stop all have the same effect that is, twice as much light on the film.
But it needs a constant, or a conversion factor to skip from the ASA system to the camera settings. It turns out to be 25. It doesn't mean anything more than saying a kilogram is 2.24 pounds.
#4 Chris Jordan
Chris Jordan
  • 11 posts
Posted 24 March 2008 - 08:32 AM
Thanks for your help. I believe that answers my question.
#5 Xavier Plaza
Xavier Plaza
  • 288 posts
  • Guayaquil - Ecuador
Posted 24 March 2008 - 11:55 AM
As David say this formula could be your best friend. If you don't have near you and you need this guide numbers in only a few minutes you can fill and make your Incident Key Light table... Skills in math is your key...
Xavier
