Materials used in building a green screen room
22 replies to this topic
#1 Mo Kamal
Mo Kamal
  • 30 posts
Posted 23 March 2008 - 09:26 AM
Hello,
I have a spare room that I decided to use for chroma keying, I searched around quite a bit, but all the info I could find is on lighting green screens or handling the footage in post. What I really need is a guide or even some pointers on the actual process of building the set. For example what brand of paint to use, what materials would work best for the cycs and for the floors. Should I setup a grid for lighting?, if so how should it be done?
I realize those are a lot of questions and that most of the time the process needs tweaking and depends on the type of shoot, but still I am hoping there is a standard setup somewhere that pretty much would be versatile enough to handle most types of shoots.
#2 Chris Keth
Posted 24 March 2008 - 12:51 AM
The first thing you should ask yourself is whether or not your spare room is really big enough for that. I don't know of any houses with a large enough room with high enough ceilings to be useful for that. You really have to separate your subject from the screen by at least a healthy 10 feet. That means that the screen must be larger to compensate.
I wouldn't even consider it unless you have 12-14 foot ceilings, a wall 20 or 30 feet wide for the screen and 30 or 40 feet of depth to back off a camera and have lights, monitors, a crew, etc. That's all a pretty bare minimum. Anything less and your subjects suddenly can't move and the usefulness of the screen will be severely hampered.
#3 Mo Kamal
Mo Kamal
  • 30 posts
Posted 24 March 2008 - 05:20 AM
floor to ceiling = 11.5 ft
the widest wall = 42.6 ft
the other wall = 15.7 ft
I never said the room was in my house :), it used to be a storage room owned by relatives, and now they aren't using it.
#4 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 24 March 2008 - 02:22 PM
Well you've basically got an "insert stage," with a large staging area... Since the room is only 15ft one direction you can't really make use of the 42ft wall as a background. That means you have a long "tunnel" with a 15 x 11 wall at one end.
The simplest thing would be to get a 12x12' greenscreen backdrop and make a custom frame; the tiny bit of extra material will allow you to curve it at the bottom a little.
#5 Mo Kamal
Mo Kamal
  • 30 posts
Posted 24 March 2008 - 04:58 PM
Thats exactly what i was planning to do, I was planning to use the smaller wall (15 x 11) for the background, the reason I need the green screen is to use on small indy type projects, like short films, and general practice and experimentation, before I move on to a bigger permanent place a coule of years down the road, for that purpose I think the size would do just fine. Do you agree?
The reason I want to use paint and cycs and all that instead of a backdrop, is that the experimentation and building process is a big part of my goal, and because someone else is paying so to some extent money and effort are not a problem.
Those were my initial thoughts but ofcourse I'm not stuck on them, i'm here for advice.
#6 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 24 March 2008 - 05:31 PM
If it's only to learn how to shoot green screen, then I think a simple (and flexible) approach would be best. Get a cheap greenscreen and build a frame out of lumber or whatever, and you'll also have a greenscreen you can take on location with you.
http://www.filmtools...la10x12chg.html
Compare that to the trouble and expense of building a smooth wall that you can put stands behind for backlighting, and painting it with multiple coats of chroma green paint (it's not that cheap).
I would advise keeping the space flexible (hence the backrop and frame). In that size space you're going to constantly be repositioning things for various shots. Your lighting/flagging is going to take up a good portion of that 11x15 space, so it's not like you'll always have a full 11x15 area or background for shooting.
#7 Mo Kamal
Mo Kamal
  • 30 posts
Posted 24 March 2008 - 06:18 PM
Keeping the space flexible does sound very appealing, I dunno why but for some reason I felt that having the wall painted would give me a more durable green screen than a flimsy fabric. like I said I have no experience with all this, so I'm not arguing with what your saying but out of curiosity, why do people paint walls when you have the obvious disadvantage of not being able to reposition?
#8 Mo Kamal
Mo Kamal
  • 30 posts
Posted 24 March 2008 - 06:38 PM
Also another thing that made me feel paint would be better than fabric, was that I thougt that if I had the actors walking on a painted floor it would be much easier to key than if they were walking on a sheet of fabric. Am I totally off there?
Even though the room is small, I was hoping to have the option of shooting people walking (with their feet in the frame).
Edited by Mo Kamal, 24 March 2008 - 06:42 PM.
#9 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 24 March 2008 - 08:36 PM
People usually use chroma paint instead of fabric when they need to cover a large area with multiple planes (floors and walls) that would be too difficult to rig with fabric (the idea is that you stretch the fabric tightly across a frame, so there are no wrinkles).
But in the case a of a "curved cyc" wall, the construction of the wall and transition to the floor has to be pretty precise. It's a lot more work and expense than is really necessary for someone just trying to learn how to use greenscreen.
Yes, a painted curved-cyc will allow better head-to-toe shots for keying, but it's not impossible to do with fabric.
#10 Mo Kamal
Mo Kamal
  • 30 posts
Posted 25 March 2008 - 04:37 AM
I know I will be buying a fabric backdrop for it's portability around the room and to take outside if needed, but I'm still thinking that because I have the room and the time, and because I have someone willing to pay the expenses, it would be silly not to try and paint and make the curved cycs, especially since I know I will want to know how it is done for use in bigger projects in the future.
I really appreciate your time and advice Michael, and for almost anyone with a room like the one I described, your advice would probably be spot on, but for me I wanna get into the diy spirit and play around with some paint :)
Edited by Mo Kamal, 25 March 2008 - 04:39 AM.
#11 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 25 March 2008 - 05:18 AM
Don't forget that lighting is just as important to shooting a good green screen element. Have fun...
#12 Mo Kamal
Mo Kamal
  • 30 posts
Posted 25 March 2008 - 06:29 AM
Thanks, I expect it will be fun once I get started, though for now I'm still clueless when it comes to which materials to use and especially clueless on specification for the curved cys and for the floors.
Edited by Mo Kamal, 25 March 2008 - 06:30 AM.
#13 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 25 March 2008 - 12:39 PM
http://www.procyc.com/whatisacyc.php
http://www.procyc.com/faq.php#22
http://www-personal....to/cyc/cyc.html
http://www.filmtools...chkeygrvip.html
#14 Mo Kamal
Mo Kamal
  • 30 posts
Posted 25 March 2008 - 07:21 PM
Thank you for the links Michael, and sorry it took me a while to post. I contacted procyc.com and I'm waiting for them to send me a quote. Their stuff looks so cool that I might just forget about building the cycs myself (if they're not crazy expensive).
#15 Mo Kamal
Mo Kamal
  • 30 posts
Posted 26 March 2008 - 05:59 AM
I just found out that I miscalculated the dimensions of the room, the wall I'm gonna use is 25ft wide not 15, this probably doesnt change much for this thread, but it makes me a bit happier.
#16 Jeff Scruggs
Jeff Scruggs
  • Chicago
Posted 26 March 2008 - 12:26 PM
Every one's posts are pretty spot on, I learned through trial and error about the light reflection from the screen when you are too close. this is what we used to actually paint a tarp from the home center. Does an ok job, kind of heavy, but we don't move it around much. Pulls agood key with the right lighting and spacing.
http://www.detonatio...green_paint.htm
#17 Mo Kamal
Mo Kamal
  • 30 posts
Posted 27 March 2008 - 06:26 PM
So Jeff, do you have any pics of your chroma key setup?
#18 Tyler Leisher
Tyler Leisher
  • 91 posts
  • El Segundo, CA
Posted 29 March 2008 - 06:09 PM
We had a very small room, maybe 8x8 in my previous studio setup. We had painted one of the walls chromakey green, and we backlit it as well as lighting in front of it... we were able to get a really good key with that. I'm sure having a larger room would be better, but it can be done with less.
#19 Mo Kamal
Mo Kamal
  • 30 posts
Posted 29 March 2008 - 06:44 PM
of course it can be done, I was playing around once and pulled a perfect key off my bedroom white wall with only sunlight coming in through the window, but still this doesn't mean that this is the best way to go, I think what the Michael Nash was saying is that if you wanna have a professional setup with a big crew and a bit of equipment then things will be cramped and so you might as well use a portable backdrop.
For me though, the next step now would be figuring out how to build the cycs, the links above that Michael Nash provided contain an illustration that I think may be helpful. also I found this thread:
http://www.cinematog...onstruction.htm
#20 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 31 March 2008 - 08:42 AM
You can pull keys from surprisingly bad setups. I've shot so many greenscreened interviews in cramped doctors offices on 6x6 flexfills its ridiculous. At that point, it's all about lighting to get seperation.
This is what we use to paint our cyc wall: http://www.bhphotovi...reen_Paint.html
It's not cheap and it takes two coats. Generally when we have to paint the studio for a project there is a built in paint charge as it's constantly going back and forth from white to green to blue, etc. and it gets quite expensive.
Good Luck!
