Cloverfield
#1 Benjamin_Lussier
Benjamin_Lussier
  • 136 posts
  • Digital Image Technician
  • Canada
Posted 26 March 2008 - 08:23 AM
I have a few questions regarding Cloverfield. Most specifically the R&D that was done to integrate CGI with video as opposed to film.
Can anyone help ?
Thx
Benjamin
#2 Hugh Macdonald
Hugh Macdonald
  • 16 posts
Posted 26 March 2008 - 11:28 AM
Didn't work on it myself....
I did read an article about it, though, that said that they shot the VFX shots on a much higher-end camera than the one that they wanted it to look like it was shot on - something like a Viper or Genesis.... And then degraded the VFX shots in post to match the rest of the footage.
#3 Chris Pritzlaff
Chris Pritzlaff
  • 187 posts
Posted 26 March 2008 - 04:59 PM
The VFX plates were shot on the CineAlta F23 and then degraded to match the rest of the footage.
I hear that the rest of the movie was shot on an HVX but I can't find anywhere that confirms that
#4 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 26 March 2008 - 05:09 PM
Check the American Cinematographer Article on it.
#5 Hugh Macdonald
Hugh Macdonald
  • 16 posts
Posted 26 March 2008 - 07:15 PM
Ah - okay - thanks - I knew it was on something somewhat better than how it was meant to look...!
That's what I'd heard too...
#6 Mike Simpson
Mike Simpson
  • 113 posts
  • Austin
Posted 26 March 2008 - 11:05 PM
From what I understand, for the scenes without any effects, it was HVX and alot of times just given to the actor. Heavy effects were the f23 and low light was the genesis.
#7 Benjamin_Lussier
Benjamin_Lussier
  • 136 posts
  • Canada
Posted 31 March 2008 - 01:59 PM
Hey Guys... thanks for replying to the post...
But my original question was more about the R&D they did to comp the CGI with video.
Im mostly interested in the Motion Blur. The way I see it the renders HAD to be HDR (open EXR or smtg) because of the way the bright sources of light leave a streak as the camera shakes... HOWEVER... its not just that... These streaks have a very video edge to them... very unlike the thing's ud get from a str8 3D render with motion blur.
I should prolly post on a VFX forum.
Edited by Benjamin_Lussier, 31 March 2008 - 01:59 PM.
#8 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 31 March 2008 - 02:49 PM
Most VFX studios use EXR for their renders these days, that's pretty much a given. I expect that they had several different shake nodes (or scripts) designed to emulate certain image characteristics of the HVX-200 such as noise, pixel-shifting, 4:2:2 compression, edge-enhancement, etc on the rendered CG elements.
The way to add those aspects to the image is to figure out how they work in real-life first, like for example 4:2:2 compression is easy to fake by converting an RGB image into an YCrCb image and then apply a 2 pixel mosaic to the Cr and Cb channels and then convert the YCrCb back into a RGB image. Noise or gain may be something you either sample or overlay from reference footage - ie. by shooting 30 seconds of black using different amounts of gain should cover you.
If you looked at the CG elements by themselves you'd see an image that looks fairly clean (even the motion blur), it's much easier in cases like this to downgrade the image in the composite.
#9 Hugh Macdonald
Hugh Macdonald
  • 16 posts
Posted 31 March 2008 - 05:32 PM
Will I get shot for saying this? I hope not....
Do check out (and ask this) on vfxtalk.com (it's mainly about the 2D side of things over there) - there are a number of people from both DNeg and Tippett who will, I'm sure, be able to help you out on this.
