PL mount - how thick should the locking tabs be?
#1 Henri Titchen
Henri Titchen
  • 125 posts
Posted 31 March 2008 - 03:03 AM
I have a couple of inexpensive stainless steel Arri standard to PL mount adapters. They came from different continents/manufacturers.
I am experiencing a problem where the adapters are too thick to be able to lock into the lens mount of a PL mount camera.
The "locking tabs" or "wings" of the mount are too thick for the PL mount on the camera to lock.
Can anyone let me know what the thickness of these should be? The "tabs" on one of mine measures about 2.25mm the other measures about 2.20mm thick. (I used a micrometer). I measured an Arri plastic PL mount camera "dust cap" and the tabs on it are about 2mm thick.
What should the correct thickness be?
Thanks From,
Henry.
#2 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 31 March 2008 - 05:38 AM
Thanks From,
Henry.
The original Carl Zeiss Opton 18 mm lens have Arri PL lens mount with thickness of " washer" 2.00 mm with facet (bevel) from camera side 1x45', lens side 0.5x45'.
If you need other dimensions, send me personal letter.
#3 Henri Titchen
Henri Titchen
  • 125 posts
Posted 31 March 2008 - 06:39 AM
Thanks Olex, much appreciated,
I think both of the adapters I was describing are very slightly out of specification.
Thanks From,
Henry.
