Redcode 28 vs 36
15 replies to this topic
#1 Jayson Crothers
Jayson Crothers
  • 351 posts
Posted 07 April 2008 - 02:28 AM
I'm about to start shooting a new feature film and we're shooting on the RED; the decision came very last minute to go from HD to the RED and I'm in a bit of a race to learn as much as I can about the system.
One thing I can't seem to find a clear answer to is the difference between Redcode 28 and Redcode 36 - the only hard information I can find is that shooting with Redcode 36 limits some frame rate options for me, but what do I gain with 36 over the default 28?
Thanks everyone!
#2 Josh Gannon
Josh Gannon
Posted 07 April 2008 - 04:24 AM
Redcode 36 is simply a higher bitrate 36MB/s rather then 28MS/s.
I would recommend shooting all your sync stuff at 36 for a little extra quality and latitude when it comes to grading (NOT EXPOSURE LATITUDE! it is 6 stops no matter what. I have extensively wedge tested these cameras. +2 1/2 stops. - 3 1/2 stops)
Obviously Redcode 36 will take up more hdd / cf card space.
But as a rule of thumb always chose the 36MB/s codec where possible.
#3 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 07 April 2008 - 06:59 AM
What do you mean by "6 stops" and how exactly are you measuring it?
What have you been shooting so successfully?
#4 Brian Drysdale
  • 5193 posts
Posted 07 April 2008 - 08:26 AM
It's lower than the approx 9 1/2 stops most people have been getting in their tests.
#5 Jayson Crothers
Jayson Crothers
  • 351 posts
Posted 07 April 2008 - 08:59 AM
Thanks Josh - shooting my tests tomorrow, so hopefully I'll have something to report back here to everyone.
#6 Mike Williamson
Mike Williamson
  • 534 posts
Posted 07 April 2008 - 02:06 PM
Looking forwards to hearing your results and thoughts, Jayson. What kind of post workflow are you taking it through? Any chance you're doing a filmout?
#7 Eric Diosay
Eric Diosay
  • 4 posts
  • Toronto
Posted 08 April 2008 - 07:19 PM
I would be interested in hearing about this, too. Good luck with your tests.
BTW, I thought the RED has 11+ stops? :blink:
#8 Hunter Hampton
Hunter Hampton
  • 170 posts
Posted 27 April 2008 - 12:38 PM
I thought the Red has 11+ stops also? Maybe it changes based on LUT's?
#9 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 27 April 2008 - 12:55 PM
Never trust a manufacturer's specs ;)
There's stops and then there's useable stops. No camera has as high a latitude as its manufacturer claims.
#10 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 27 April 2008 - 12:58 PM
Are we talking latitude or dynamic range? They're two completely different things.
#11 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 27 April 2008 - 02:59 PM
Sorry I meant dynamic range.
#12 DJ Joofa
DJ Joofa
  • 149 posts
Posted 27 April 2008 - 09:52 PM
What is the difference?
#13 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 27 April 2008 - 10:09 PM
Latitude is the amount an image can be over- or under-exposed and still yield an acceptably "normal" looking image after color correction (and/or processing, in the case of film).
Dynamic range is the range of brightness a system can capture, between solid black and solid white.
People often use the term latitude when they're talking about dynamic range, which leads to all kinds of confusion. A camera that claims to have "11 stops of dynamic range" can capture some detail in a gray card between roughly 5+ stops under- and 5+ stops over-exposed (give or take, since the over- and under-range rarely match). That doesn't mean that the camera has 11 stops of latitude though, because you can't recover any highlight detail in an image that's 5 stops over, or shadow detail in an image that's 5 stops under. In that hypothetical system it's more likely that you've got about + or - 2 stops of latitude.
#14 DJ Joofa
DJ Joofa
  • 149 posts
Posted 27 April 2008 - 10:33 PM
Thanks for the explanation. So basically what you are saying is that latitude decides your "wiggle room" -- the amount by which you can shift your captured range up and down, just like a slider, along the full range of signal values available to you.
#15 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 27 April 2008 - 10:42 PM
Yes. Maybe a better definition would have been:
Latitude: margin of error for exposure. Usually expressed in + and - values.
Dynamic range: total range of light values the system can capture. Usually expressed in total values.
#16 Stephen Price
Stephen Price
  • 84 posts
  • Digital Image Technician
Posted 28 April 2008 - 02:45 AM
How does one do a 'wedge test'? i'm unsure of the process involved to find the latitude of a camera, could anyone please elaborate?
