Beaulieu charger bulb
#1 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 11 April 2008 - 09:09 PM
Does anyone know what is the specification of the pilot bulb inside the original Beaulieu 5008 charger rated at 50mA. You know the square grey box type.
I also wouldn't mind finding out the specs for the 4008 (30mA) and the R16 (90mA) chargers.
Thanks!
Jean-Louis
#2 Jim Carlile
Jim Carlile
  • 464 posts
Posted 12 April 2008 - 04:18 AM
It's an LED isn't it? If so, it should never go out-- if it does, there's a bigger fault than that.
They're just trickle chargers-- you could use any of close voltage the only problem would be the connectors.
#3 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 12 April 2008 - 07:14 AM
Hi Jim,
The ones I'm talking about use an actual bulb and I think the bulb might have something to do with the current regulation. That's why I need the exact value. Besides, I want to restore the unit to it's original functioning.
Cheers,
Jean-Louis
#4 Bjorn Andersson
Bjorn Andersson
  • 18 posts
Posted 13 April 2008 - 08:21 AM
Hi Jim,
Cheers,
Jean-Louis
4008: 30mA charger, 2,5V 0,06A fuse bulb.
5008: 50mA charger, 6V 0,6A.
R16: 50mA charger, 6V 0,6A.
R16: 90mA charger, 1,5V 0,1A.
I have several.
#5 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 13 April 2008 - 01:24 PM
I have several.
Thank you Bjorn, that is exactly the information I needed.
I would like to obtain some. Please contact me by private message to give me information on ordering.
Thanks.
Jean-Louis Seguin
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 22 October 2009 - 12:05 PM
I finally did order the bulbs from Bjorn and they work fine.
However, I should correct some information.
Bjorn gave this as the different bulb's rating:
No problem for the 4008 and R16 90mA information.
For the two 50mA chargers, it should read:
5008: 50mA charger, 6V 0,6W (which is 0,1A or 100mA)
R16: 50mA charger, 6V 0,6W (which is 0,1A or 100mA)
Cheers,
Jean-Louis
#7 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 23 October 2009 - 12:11 PM
Cheers,
Jean-Louis
The bulb is a part of the circuitry and the thing doesn't work when the bulb is loose or broken.
The bulb is a standard component and can be bought everywhere. Check for example www.conrad.de
Or shops around the corner so to say.
