ultraprime and s4 eith sr3
12 replies to this topic
#1 Matias Nicolas
Matias Nicolas
  • 157 posts
  • Buenos Aires, Argentina
Posted 19 April 2008 - 10:17 AM
hello, I have one doubt, ... it is posible to use the ultraprime lenses or s4 with an sr2 or sr3? is this posible? cause you have the eyepiece near the lense mount ... thanks..
#2 Mike Simpson
Mike Simpson
  • 113 posts
  • Austin
Posted 19 April 2008 - 09:28 PM
I had this issue come up when I called the rental house trying to get a set of lenses. The were skeptical, but the owner of the SR2 tells me that he has put both lenses on his camera no problem (I will find out in two weeks for sure). You will probably want a bridge plate for support though. Cant speak for the SR3.
#3 Chris Keth
Posted 19 April 2008 - 10:01 PM
I am pretty sure the eyepiece is too close for them to fit. That was one of the bragging points of the 416, that the larger diameter primes would fit correctly.
#4 Alex Worster
Alex Worster
  • 113 posts
  • Film Loader
Posted 19 April 2008 - 10:30 PM
This is just a guess because I've never tried putting Ultra Primes or S4s on an SR but I have used both lens so am fairly familiar with their form factors. Chris is right, the 416 says it fits Master Primes and the SRs don't so that would rule S4s out since there are similarish in size. Ultra Primes are smaller than S4s so those might work. So, S4s no but you might be able to get Ultra Primes on there. That's just an educated guess though.
Edited by Alex Worster, 19 April 2008 - 10:31 PM.
#5 Camillo Foramitti
Camillo Foramitti
  • 36 posts
  • 2nd Assistant Camera
  • Vienna, Austria
Posted 20 April 2008 - 04:21 AM
I have used both S4s and Ultra Primes on SR3s without a problem. With some of these lenses you have to move the viewfinder a little bit up but thats all.
#6 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 20 April 2008 - 12:29 PM
So have I, the fit when you move the viewfinder up a bit like Camillo said.
#7 Alex Worster
Alex Worster
  • 113 posts
  • Film Loader
Posted 20 April 2008 - 01:35 PM
Good to know. Nothing trumps real experience.
#8 Chris Keth
Posted 20 April 2008 - 02:58 PM
Ditto. Now I'm curious why Arri would tout the 416's ability to use those lenses when the current standard for S16 already can. :blink:
#9 Camillo Foramitti
Camillo Foramitti
  • 36 posts
  • Vienna, Austria
Posted 20 April 2008 - 04:29 PM
I haven't tried it but maybe you can't use the Master Primes on a SR3.
And I am guessing Arri's marketing had to provide some reasons for shelling out the money for a new camera.
#10 Johnathan Holmes
Johnathan Holmes
  • 26 posts
  • New York, Toronto
Posted 13 June 2008 - 12:08 PM
Ultra Primes and Cooke S4's will work on All SR models, including SR3.
Be aware when using the Cookes as the eyepiece clearance is very small (but still clears) and often if the eyepiece is pushed down by the operator, it can move the iris ring.
#11 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 13 June 2008 - 01:17 PM
Used UP with an SR3 Advanced earlier this year. It works but as mentioned you have to move the eyepice a little upwards, never tried with S4s or MasterPrimes.
#12 Rory Hanrahan
Rory Hanrahan
  • 175 posts
  • NYC
Posted 13 June 2008 - 03:31 PM
S4's fit (just did a feature with this config), Master Primes are too fat.
#13 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 13 June 2008 - 11:34 PM
Most (but not all) UltraPrimes fit; all Cookes fit. But they just barely make it, and it can be a bit awkward to operate since the viewfinder is extrememly limited in position. The Master Primes will not fit. This is all ppart of the redesign in the 416. On a side note, all Aatons, even LTR7 cameras from the 70s will fit with any of these lenses no problem.
