How do RED determine SD speed-worthiness?
#1 Luke Haywood
Luke Haywood
  • 61 posts
  • Electrician
Posted 20 April 2008 - 03:43 AM
I've read that RED state that most larger capacity SD cards do not meet the manufacturers claimed Read/Write speeds.
Does anybody know how this is detremined, apart from simply putting the SD card in the camera and trying to record onto it?
If that's all they do, I can't help wondering whether the problem might be with their camera, and that some cards are simply more tolerant of the interface.
I was also wondering if you can use 4K SD cards. I know that would only give you about 3 minutes of 4K, but 3 minutes was all you got out of a Super-8 cartridge, and lots of good stuff has been shot on that :lol:
I know an importer of SD cards who is willing to lend me some samples with a view to seeing if they are "RED-worthy" . Some of the Toshiba ones are marked "Ultra High Speed" , whatever that may mean.
Not having ready access to a RED One, I was wondering if there is some other way to determine the actual speed performance of an SD card.
Edited by Luke Haywood, 20 April 2008 - 03:45 AM.
#2 Matthew Rogers
Matthew Rogers
  • 175 posts
  • Knoxville, TN
Posted 20 April 2008 - 04:36 PM
Well, the whole problem with what you are talking about is that RED doesn't record onto SD cards--it uses Compact Flash cards. Also from my understanding, not just any CF cards will work. I believe starting in beta build 15 that RED stopped letting you use other cards that didn't ID as RED cards. I believe they did that because people were having so much trouble with third party cards that said they were 300x, but really were not. Not 100% positive on this info, but it seems like I did read something like it at RU.
Matthew
#3 Luke Haywood
Luke Haywood
  • 61 posts
  • Electrician
Posted 25 April 2008 - 09:09 PM
Matthew
My Bad. I actually wrote "CF" when I was composing my original post, and then for some reason I got the idea I really meant "SD", and changed them all. All I remembered was that they were the type of cards that DON'T work in my still camera :lol:
So are you saying that RED will not allow you to use anything but the CF cards they supply?
#4 Matthew Rogers
Matthew Rogers
  • 175 posts
  • Knoxville, TN
Posted 25 April 2008 - 10:24 PM
Kinda. There evidently were some Sony cards that worked in build 14 and before that now don't work in build 15. However, I found out yesterday that there are some Lexar cards (probably the same as the RED cards, RED just rebrands them) that you can use and after rebate are only $90! It seems that RED has found VERY few cards that are fast enough. It's a shame that RED couldn't have designed a small RAID-0 module out of two compact flash cards. That would have been VERY cool and they could have used slower cards.
Matthew
