Fuji downspooling for A-Minima
#1 Aurora Gordon
Aurora Gordon
  • 7 posts
Posted 05 May 2008 - 01:05 PM
Hi all,
Has anyone had any experience shooting with Fuji stocks and the A-Minima? I'd really like to use Eterna 250D, but this is the first time I've had to downspool to the 200ft daylight spools.
If anyone has any knowledge of the scratching risks/if it's worth it at all, I'd greatly appreciate the feedback.
#2 Douglas Hunter
Douglas Hunter
  • 356 posts
Posted 05 May 2008 - 03:23 PM
Hi all,
I spooled down some Fuji 64D for the A-minima last month. I did it at Yale. It worked just fine, no scratches, no dirt. Just make sure to emphasize to the lab that the A-minima's wind is emulsion out.
Edited by Douglas Hunter, 05 May 2008 - 03:24 PM.
#3 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 05 May 2008 - 06:05 PM
I have used factory sealed 200' Fuji 500T 8672 16mm loads. You can't get those now? I didn't use it on A-minima, it was my ACL, and I still have a can left in my freezer.
I would try to see if you can get some of those 200' Fuji factory sealed loads somewhere, I sure hope they didn't discontinue them!
Edited by Saul Rodgar, 05 May 2008 - 06:09 PM.
#4 Robert Houllahan
Robert Houllahan
  • 1627 posts
  • Providence R.I.
Posted 05 May 2008 - 08:02 PM
The A-Minima uses special plastic split reels, not the typical 200' metal ones, plus the film is wound emulsion out. It is easy to wind film onto a aminima reel and they have a little lip on them, for extra light tightness, that also kinda lets you know when they are full...
-Rob-
#5 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 06 May 2008 - 08:54 PM
-Rob-
Duh!
You are right, I forgot. I have a A-minima fresh stock can. I have heard it can be used on an ACL (breaking the plastic sides and doing a wrong side feed loop) but I haven't tried it yet. And clear forgot about the flanged cores and emulsion out situation on A-minimas.
#6 Ole Dost
Ole Dost
Posted 21 June 2008 - 03:11 AM
Duh!
I already used Aaton-A-Minima loads for a non Aaton-A-Minima Camera, the russian made Kinor 16 P that also requires film wound emulsion out. No problems so far. You just turn the plastic sides counterclockwise firmly, then they┬┤re off. What is left ist 200ft of film wound emulsion out sitting on a core, that fits on every common core axis perfectly. When my Eclair ACL is back from servicing, I will try the same with this camera. There should be no problem at all.
Regards,
Ole
#7 Michael Lehnert
Michael Lehnert
  • 1095 posts
  • London, UK / Basel, CH
Posted 27 June 2008 - 10:26 AM
Works with ACL while shooting as described by Saul; let's wait for results.
