Konvas 1M (7M) Motor doesn't start, not sure about power supply
#1 Kevin Blake
Kevin Blake
  • 11 posts
Posted 10 May 2008 - 07:05 AM
Hello,
Hello I have a Konvas 1M type camera, motor and power supply.
I press the button on the motor and nothing happens.
I flip the switch on the power supply and press the button on the motor again and nothing happens.
What am I expecting, what should happen when I do this?
Am I missing a cable or something else?
The camera is:
A Konvas 1KCP-7M 925566 (apparently the last in the line of the 1M series).
The motor is:
# starts with 15. It is 15 3NCC 7500381.
Pictures of the motor:
http://img.auctiva.c...132373271_o.gif
http://img.auctiva.c...132373274_o.gif
http://img.auctiva.c...132373277_o.gif
The power supply is:
# also starts with 15. It is 15 3NCC.
31009 (? it's a little worn out, hard to read this part)
Pictures of the power supply:
The power cord is attached to the power supply.
http://img.auctiva.c...132373279_o.gif
Notice that there is no cable attached to the 4-hole connector labeled CBET. I don't have this cable, is that my problem??
http://img.auctiva.c...132373280_o.gif
http://img.auctiva.c...132373285_o.gif
Here I have opened the power supply to show you what's inside
http://img.auctiva.c...132373284_o.gif
This is the camera with the motor attached. The motor is attached to the power supply.
http://img.auctiva.c...132373267_o.gif
#2 Rafael Pankratau
Rafael Pankratau
  • 61 posts
  • Belarus, Europe
Posted 10 May 2008 - 07:47 AM
Hi Kevin.
First of all, there is no picture of the battery compartment of the controller (power supply unit). This is opposite part of the electronics you've pictured. So, please check if you have a battery installed :-) I'm 99% sure that there is just no battery.
"CBET" means "Light" in Russian. It is for external lamp, and doesn't matter.
#3 Kevin Blake
Kevin Blake
  • 11 posts
Posted 10 May 2008 - 04:21 PM
Hi Rafael,
Thanks a million, now I see and understand how this thing works. You were right there's no battery.
Picture of the battery compartment of the controller (power supply unit):
http://img.auctiva.c...132497792_o.gif
Picture of the battery compartment cover. It has these 3 silver latches made for opening the battery compartment, pictured for anyone having the same problem:
http://img.auctiva.c...132497779_o.gif
Thanks again! I"m not lost anymore. :)
So I'm wondering if Raf, you or anyone could tell me what kind of battery is requiered?
Edited by Kevin Blake, 10 May 2008 - 04:25 PM.
#4 Kevin Blake
Kevin Blake
  • 11 posts
Posted 10 May 2008 - 04:35 PM
Sorry; this is the correct link to the picture of the battery compartment of the controller (power supply unit):
http://img.auctiva.c...132500773_o.gif
#5 Henri Mathieu
Henri Mathieu
  • 21 posts
  • Bruxelles,Belgium
Posted 10 May 2008 - 04:53 PM
You can find a great number of post from Olex Kolinychenko
http://www.cinematog...showtopic=26537
regards
H.MATHIEU
#6 Henri Mathieu
Henri Mathieu
  • 21 posts
  • Bruxelles,Belgium
Posted 10 May 2008 - 05:16 PM
regards
H.MATHIEU
Olex Kalynychenko sorry for the error
