Good 2perf, Bad 2perf, Ugly 2perf.
#1 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 18 May 2008 - 09:47 AM
I'm aware of some here that think 2-perf is an insufficient format. Sure, it's less real estate than full academy frame. But, even on SD TV with 4:3 framing (cropped out sides), it looked pretty darn good. As a kid, I grew up on local affiliate TV showing these movies from a badly telecined 16mm print. These latest high res'd digital presentations are really stunning, even on my TV.
Another thing I noticed is how luminous and spectral the images looked. That old direct lighting with arcs and tungstens really sparkles in digital scanning. It also occurred to me the merits of Leone's notorious directing style- jumping from long shots to close-ups. It may have been influenced by the slow film stocks and the limits of the existing lighting. If you keep the shots long then you don't need fill light. If you keep the shots close then the cans you have can adequately do the job of fill under that blazingly bright sunlight. It's the medium shots that take too much light to try to fill. Those are the shots that eat up the time and budget. I can increasingly see the benefits of bouncing back and forth from long to close-up shots.
#2 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 18 May 2008 - 10:21 AM
I don't know if they're aware of just how close 2-perf is to 2:35/1 Super 35, both in terms of frame size and projected results. I work with both formats, and they are close enough in look, especially with modern film stocks, to mix on the same project.
#3 David Mullen ASC
Posted 18 May 2008 - 11:34 AM
I don't think Leone was avoiding medium shots to save money on lighting. On 50 ASA stock, the wide shots inside needed a lot of light, and his deep focus lighting and staging often meant that even in a close-up there was a lot background also in the shot. If Leone really wanted to save money on lighting he wouldn't have asked for a deep focus look from his DP.
And there are plenty of medium shots in his movies, just that people notice the tight close-ups.
