Bright surfaces
#1 Matteo Castelli
Matteo Castelli
  • 22 posts
  • Italy
Posted 21 May 2008 - 05:07 PM
Hi everybody,
I wonder how to measure a bright surface, such as a film screen, or something similar..
Something that doesn't receive the light, but where the light comes from..
thank all folks! B)
#2 Adrian Sierkowski
  • 7373 posts
Posted 21 May 2008 - 05:09 PM
Spot meter woudl give oyu the reading to make that surface = to 18% grey, from there the zone system helps one set it as white, or assort it a brightness.
#3 Matteo Castelli
Matteo Castelli
  • 22 posts
  • Italy
Posted 22 May 2008 - 02:27 AM
obviously you mean the reflection reading of the surface..
so I should start from it and then I have to balance the other light with my bright surface to achieve my purposes, right?
#4 Adrian Sierkowski
  • 7373 posts
Posted 22 May 2008 - 04:57 PM
Basically, by using the reflective meter readings (spot readings) you're recieving the stop to take whatever object @ whatever intensity and turn it into 18% grey. So exposing a white object at the spot meter reading, or building your lighting around that reading alone, without compensating to make it white again (by opening up 2 stops or so) will underexpose everything.
Hope that makes some sense.
