Film Donated to me: Questionable Condition
#1 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 21 May 2008 - 05:28 PM
I have 400ft of 250D it was neglected, not refrigerated, but probably had most of its life slightly under room temperature. Dummy load or perhaps have some fun with it. Its about a year old. How sensitive is film to hazing or other strange things.
#2 Adrian Sierkowski
  • 7367 posts
Posted 21 May 2008 - 06:36 PM
Only way i know of to be sure of the level of problem with the film would be a clip test from a lab. It'll let you know how much fogging has happened to the film, and therefore how to expose to get above that base fog level. They're cheap, call your local lab for pricing.
#3 Douglas Hunter
Douglas Hunter
  • 356 posts
Posted 21 May 2008 - 10:48 PM
A snip test will tell you want you need to know for sure. But I also want to add that 7246 is a pretty hardy stock. A year a room temp will most likely have no effect. I shot 7246 that was stored at room temp for 3 years and the results were fine. I did snip test it first and the test showed it was still well within range.
#4 Adrian Sierkowski
  • 7367 posts
Posted 22 May 2008 - 04:58 PM
i thought 250D was 7205?
#5 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 27 May 2008 - 02:25 PM
Vision1 was 46
