K-3 scratches
#1 David Auner aac
David Auner aac
  • 1117 posts
Posted 25 May 2008 - 12:30 PM
Hi folks,
I have just put my K-3 through a disassembly and cleaning procedure and removed the loop formers as well. Prior to that it was scratching my film all over the place.
Now, I have only two major occurrences of scratching. You can see both in the attached picture. The longitudinal scratch on the top is where the perfs would be and so be a non-issue in R16, right? If I can I'd like to get rid of it nevertheless. But what about the ones in the middle of the image area? What might be causing these?
Thanks, Dave
#2 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 26 May 2008 - 02:34 AM
Hi folks,
Thanks, Dave
The scratching from side of emulsion ?
If we have scratches from emulsion side.
The longitudinal scratch - i think, need check of film gate detailed, and re-polishing.
The middle scratch - can be - big size of upper loop. The upper loop must be small.
And need check of condition and position of plates between small rollers round of cog's wheel.
#3 David Auner aac
David Auner aac
  • 1117 posts
Posted 26 May 2008 - 02:50 AM
These are base side, can I ignore these?
Cheers, Dave
#4 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
Posted 26 May 2008 - 04:07 AM
Cheers, Dave
If this from side of base, I think, the longitudinal scratch - can be from leber of film counter or pressure plate of film gate.
The middle scratch - from plastic parts of post , what have of spring for press on pressure plate from side of cog's wheel.
You can compare of version of post of Krasnogrosk-1 and Kranosgorsk-3 cameras.
#5 David Auner aac
David Auner aac
  • 1117 posts
Posted 26 May 2008 - 04:22 AM
Thanks, Olex! What do I do when I have found the parts that are causing scratches? Polish them out? Using what?
Thanks, Dave
#6 Curtis Bouvier
Curtis Bouvier
  • 96 posts
Posted 31 May 2008 - 02:30 PM
Thanks, Dave
dremel would work, with a buffer bit, use on low RPM of course =]
