Reducing noise
#1 Clair Popkin
Clair Popkin
  • 4 posts
Posted 26 May 2008 - 11:11 AM
Hey I was wondering what settings/techniques you all use to reduce the noise in the blacks and dark areas, I seem to always have noise/grain even with out any gain, I have been playing around with the master ped and seeing what happens lately to try and change it- Any tips or techniques would be appreciated- Thanks!
#2 Phil Rhodes
  • 12167 posts
Posted 26 May 2008 - 11:33 AM
Reducing master ped (or any of several other black-level-related controls) will ordinarily reduce apparent shadow noise at the expense of crushing areas where it appears to solid black. Black gamma or similar controls can often crush the blacks without affecting the rest of the image.
Eventually you will get diminishing returns on this sort of chicanery, however. As you crush blacks you are effectively stretching out other parts of the image to fit, resulting in more noise in those areas. Costs you precious dynamic range, too.
#3 Glen Alexander
Glen Alexander
Posted 26 May 2008 - 12:13 PM
phil, after 56XX posts why are you still "basic" member? :lol:
#4 dan brockett
dan brockett
  • 66 posts
Posted 01 June 2008 - 02:31 PM
Hi Clair:
I have seen some pretty amazing results from Raylight MXFX http://www.dvfilm.com/MXFX/index.htm
If you want to reduce grain with HVX footage, this is the hot tip. Sorry, don't have links to the demos but you can find them if you scrounge around on the DVX User website. It really works quite well. This is a viable solution until the HPX-170 is available. HPX-170 uses same chipset as HVX-200a, which many users are claiming is MUCH less noisy than original HVX, someone said HVX-200a at +9dB gain is slightly less grain than older HVX at 0dB.
Good luck,
Dan
#5 John-Erling Holmenes Fredriksen
  • 83 posts
  • Oslo, Norway
Posted 01 June 2008 - 04:23 PM
The other solution is to light your dark areas too, lifting them a bit on set, and then bringing them down if you want in post. (Be sure to use very soft non-directional light, or it could look unnatural. You don't want a motivated source, just a bit "lighter" darks).
Edited by John-Erling Holmenes Fredriksen, 01 June 2008 - 04:24 PM.
#6 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 04 June 2008 - 01:51 AM
Do you use Final Cut Pro? I do and I've been editing for a long time but I'm now getting more into modifications in post. Could you say
how to bring the dark areas down in Final Cut Pro? Is there a way to do so without also bring the entire picture down?
Thanks.
#7 Adrian Sierkowski
  • 7373 posts
Posted 04 June 2008 - 01:53 PM
3 way color corrector in FCP will allow you to do this marginally;
aside from that, in studio 2 you could throw a curve on via apple color, and set exactly where you want your blacks/whites to start rolling off; but the render time can be a pain! (for color).
Granted, though, all these solutions will bring other areas down, just in varying degrees, ya know? The black level in color correctors also will bleed into the middle-range, and the middle into the whites; ya know? It's some fine tweaking from time to time.
