Digital Noise Removal
#1 Albert Smith
Albert Smith
  • 151 posts
  • Chicago
Posted 10 June 2008 - 09:22 PM
Ok, so I have some HVX footage with a good deal of noise....it looks as if the gain was turned on (in daylight) to around 12db. Does anyone have any ideas for either places that specialize in this or things I can do to help remove this awful noise so we can use the footage alongside other clean HVX footage.
thanks for any info!!
-Jake
#2 Timo Klages
Timo Klages
  • 39 posts
  • Germany
Posted 11 June 2008 - 07:05 AM
-Jake
maybe you can try to fix this to a certain amount with some good software.
PFClean would be an option, as well as some other plug-in sets (maybe there is something from "the foundry" to denoise, i think the "furnace" package has something like that). but i cannot say that this will look as good as your "clean" footage in the end.
althoug, these tools are not cheap...
do you have some screen-grabs to take a look at the problem?
timo
#3 Albert Smith
Albert Smith
  • 151 posts
  • Chicago
Posted 12 June 2008 - 12:35 AM
yea here is a still, ideally it would be easier if we could send out the footage and have it delt with so we don't have to run something on our system and work with it, just because it would cut into editing time.
Still link: www.lookatrubbish.com/Picture3.png
thanks again!
Edited by Jake Zalutsky, 12 June 2008 - 12:35 AM.
#4 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 12 June 2008 - 06:30 AM
Grahme Natress has a noise removal filter for FCP.
http://www.nattress.com/
#5 Pete Von Tews
Pete Von Tews
  • 89 posts
  • Concord CA USA
Posted 13 June 2008 - 01:38 AM
Perhaps adjust the levels to make it more clean, but its going to look very stylized and contrasty. That is one quick and cheap fix for the footage. Regards.
-pete
#6 Phil Rhodes
  • 12171 posts
Posted 14 June 2008 - 08:17 AM
You can probably send this out to any one of a number of post houses - just make sure they're set up to receive P2 material.
Usual thing. Get three quotes, look at examples of their work... it's just a business...
#7 Albert Smith
Albert Smith
  • 151 posts
  • Chicago
Posted 15 June 2008 - 06:30 AM
yea figured haven't made any calls yet, i have the footage in dvcproHD now too so no mxfs or anything, anyone should be able to handle the dvcproHD.
Its looking like I need to find a post house with one of these guys.
http://www.algolith....n-hd/index.html
#8 Phil Rhodes
  • 12171 posts
Posted 15 June 2008 - 12:00 PM
There are many varieties of noise reducer available; that isn't necessarily the best.
#9 Timo Klages
Timo Klages
  • 39 posts
  • Germany
Posted 19 June 2008 - 04:27 AM
sorry for not getting back to you earlier. i think phil is right when saying that you should contact some post-houses to solve your problem.
so you can keep on editing and later just replace the dirty with the hopefully clean shots... but donĀ“t expect miracles!
greets,
timo
