Your DREAM SPECS for a Digital Cinema Camera?
93 replies to this topic
#1 Tom Lowe
Tom Lowe
  • 1211 posts
  • somewhere worshipping Terrence Malick
Posted 13 June 2008 - 05:56 PM
There has been some interesting discussion lately in the Epic forum at Reduser about possible specs for a next-gen digital cinema camera. Some of the debate revolves around increasing the size of the sensor from the "legacy" 35mm cine-size negative, which is roughly an APS-C "cropped" sensor, to a "full-frame" sensor.
My dream specs:
- "Full frame" chemical still or APS-size sensor (roughly 36mmx25mm), which is also roughly the size of the legendary Vista Vision format. Who hasn't dreamed of shooting on Vista Vision?
- 6K resolution, which would easily downsample to pristine 4K for finishing
- RAW
- 60 to 120fps
- Non-linear recording on HD or solid state
A lot of the criticism about this larger format involves trying to pull focus on a sensor that size. But hey, the Vista Vision guys did it, right?
What are your dream specs?
#2 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 13 June 2008 - 06:23 PM
65mm size sensor. If you've ever compared the look of a 65mm lens and its 35mm equivalent, you'll know what I mean. The longer lenses one uses in 65mm make everything just look nice, without distortion.
Highlights that blow out gracefully like film, not that ugly clipping that the Red and any other digital camera show.
Random sampling, to avoid aliasing, like film
Better and more natural color rendition especially skintones, like film.
But I'm not holding my breath, film offers me all those things already.
#3 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 13 June 2008 - 06:53 PM
Six chips of 65mm size
a complete avoidance of codecs by storing all data as single-frame TIFF's (32-bits per color)
A solution to the color curve and blowout issue (solved by the 6 chips, which are 3 RGB + 3 RGB highlight)
A physical mirrored shutter, no electronic junk in the way
Storage directly to a RAID HD array
No audio stored on the unit
#4 Tom Lowe
Tom Lowe
  • 1211 posts
Posted 13 June 2008 - 07:15 PM
Nate, I guess we can forget portability with your system?
#5 Radoslav Karapetkov
Radoslav Karapetkov
  • 24 posts
  • Sofia, Bulgaria
Posted 13 June 2008 - 07:32 PM
OK, dreaming is free.
So, if it's a DREAM camera, then it should definitely have:
- 65mm sensor which should be:
- 8K [if CMOS Bayer], so that we could have full-luma+full-chroma mindblowing 4K out of it.
- or a 4K [future FoveoNx3 type of cinema sensor]
- RAW. There's no going back from RAW, that's for sure.
- 120 fps at 8K.
[OMG, uncompressed RAW from 8K would be... 1,3 GB\sec for 24 fps and... what? - ~ 6GB\sec for 120 fps... OK, that's futuristic :) ]
- Random sampling.
- Record to SSD drives.
- The camera should be called: "RED Lawrence" :)
- under 30k $... Ok, under 50k $ :)..... O-oh, ok, under 100k $ :(.
But for the moment... A Scarlet would do :).
#6 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 13 June 2008 - 07:51 PM
For that to happen, either:
  • Manufacturers would have to find a practical way to give silicon sensors a non-linear response, like film. They are currently hampered by the fact that nobody has the slightest idea how that could be accomplished! (Well, they understand what would need to be done, but nobody has any idea how this could be turned into a manufacturable product. The problem is that all the trouble happens in the analog part of the chip, and very little R&D is being done in that field, because commercial applications are somewhat limited).
  • Manufacturers would need to find a way to drastically reduce the noise floor of the sensor, which would allow the iris to be stopped down and so allow the sensor to linearly capture more highlights, which could then be "massaged" to produce a film-like response curve. However current generation silicon sensors appear to to be as sensitive as they are ever going to get. Once the incident photon level drops below a certain point, the noise from vibration of the silicon atoms starts to become intrusive. The chip would become exquisitely sensitive to other forms of electrical interference as well.
That (or at least the desired outcome) is actually do-able, by simply increasing the pixel count.
Unfortunately, manufacturers have to live with the physical properties of materials that are available to them. The dye filters used on a single-chip colour filter not only have to produce the right spectral response, they have to be screen-printable and UV-hardenable, and stand up to years of exposure to light without fading or discolouring. Silicon also has a far-from-ideal spectral response and the necessary IR filtering further upsets this.
Film dyes are dissolved in a water-based gel which sets on the film base at room temperature, there is a much greater range of chemicals to choose from, and each individual frame of the negative usually only sees less than a second's exposure to light in its entire operational life.
Other problems with skin tones are that our eyes are exquisitely attuned to recognizing faces and detecting subtle discolorations that may indicate disease, so we notice colour errors far more on human skin than anything else. Also real faces are not at all like the face of a painted mannequin; skin is actually a 3-D translucent gel with an enormously variable reflectivity range. (Which is why TV studios routinely apply half an inch of makeup on some people :lol:)
Which is why there is no great incentive for video camera manufacturers to try to solve these problems. On the global scale, the market demanding film capture is very small, and there already is a workable technology: film!
However, various manufacturers' attempts to provide "film-like" performance from video cameras over the years has certainly given us much better (and cheaper!) video cameras, so even if you have never shot a frame of film in your entire career, you are still benefitting from it :lol:
#7 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 13 June 2008 - 08:05 PM
There has been a lot of discussion about that on Reduser. Can I just cut to the chase and point out that that simply will not work. :lol:
Everybody seems to under the impression that you can simply discard the information from the overloaded pixels on the "full aperature" sensor, and substitute the equivalent pixels from the "ND'd" sensor. This is a very old idea. The trouble is overloaded sensors do not just overload, they inject stray current carriers into the non-overloaded sensors and degards them as well. This is the effect known as "blooming".
While you can theoretically get a small improvement in dynamic range this way, this is usually nullified (or more than nullified) by light losses and/or degradation of the signal to noise ratio by extra circuitry needed on the sensor.
While the Arriscan uses a variant of this technique in its "double-exposure" system, it does not scan film in real time, and remember, a couple of stops improvement in DR from scanned film equals a lot more stops in the actual shooting conditions, and so is well worthwhile.
#8 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 13 June 2008 - 08:12 PM
I think a lot of people would get very excited about something like a Genesis, (ie with all its "plug and play" industry workflow compatibility) but with a RED-type front end and a RED-type price.
That's probably all the industry needs at the moment.
#9 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 13 June 2008 - 10:18 PM
If you're still busy dreaming about a camera that's superior to the choices that already exist, then that camera won't be good enough either once it becomes real. You have tools available to you now that people could only dream of a short time ago.
#10 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 13 June 2008 - 11:17 PM
I should be named "Phantom."
Why y'all want to stop at 120fps?
#11 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 14 June 2008 - 01:20 PM
If you'd notice, my design would also not be in real-time. It would be storing the frames, for computers to work with later on. I am quite aware that you cannot simply discard, but I so know that with enough time and computing power, it can be done. I've even done it myself, but yes, it takes a lot of CPU time.
#12 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 14 June 2008 - 01:23 PM
No reason why you would, as there's a lot less parts within it. The RAID array would be the largest component, and it would be roughly the size of a 200' 35mm magazine. It's size should be roughly the same as the Aaton. By removing as much as possible, and instead focusing on just raw recording,
#13 Adrian Sierkowski
  • 7373 posts
Posted 14 June 2008 - 01:46 PM
Would it be wrong to ask for a digital camera that gets amazing battery life!
Seriously, though, my "dream camera," would be something high-rez with interchangeable lenses, which is affordable enough to employ in "dangerous," situations, with a small form factor.
I don't want a camera to "kill film," rather an HD content producing machine akin to the current crop of JVC/HVXs etc, that I can slap a PL lens on or a Nikon still w/o a wonky adapter and get just a bit more control of my image (something with a 2/3' chip, or hell, a 35mm chip. )
Of coure, I know that's a pip dream for now.
And/or a camera which can make me coffee. Not that it would be useful at all most of the time. .. but for those long days a built in peculator would be a dream come true :lol:
#14 DJ Joofa
DJ Joofa
  • 149 posts
Posted 14 June 2008 - 03:41 PM
This issue has been explored. It is an active research area. Please search online for nonlinear CMOS sensors. It is not terribly difficult to add an analog nonlinearity to sensors.
Edited by DJ Joofa, 14 June 2008 - 03:41 PM.
#15 Michael LaVoie
Michael LaVoie
  • 750 posts
Posted 14 June 2008 - 04:21 PM
My dream camera would be the size of the scarlet but it would shoot in 3D stereoscopic vision. 3D really is the glass ceiling untill we start building holodecks.
#16 Adrian Sierkowski
  • 7373 posts
Posted 14 June 2008 - 04:23 PM
I would kill for a holodeck. . and yes. . I am a trekkie at heart
#17 Phil Rhodes
  • 12167 posts
Posted 14 June 2008 - 05:43 PM
I think you only need two, if they're bayered and sufficiently high res, and 65mm is just wannabe chasing of an expensive format. 2/3" video is perfectly usable for dramatic work and full ap 35 is actually a pain in the neck depending on sensitivity; going any larger than that is just masturbatory "I want to shoot 65" without actually having given any thought to the grief you'll cause yourself.
Craziness. All this drivelling on about high bit depth is daft - few modern video cameras have more than four or five bits of real data. Absolutely none of them have more than eight, and yet people blast on about ten bit like it's more important than oxygen. For grief's sake just record it eight and diffusion dither it up to whatever you want - at least the noise will be gaussian that way!
I'd rather have a viewfinder that showed me what the image actually looked like, but ideally a hybrid design with information optionally superimposed over the image using a transreflective display would be ideal. Flickery mirror shutter cameras give me a headache. Personal preference I understand, but all this banging on about a colour viewfinder is gibberish when it previews neither colour, exposure or sharpness with any accuracy.
Surely you want flash.
This is just curmudgeonliness. Single system sound takes expensive make-work drudgery out of postproduction and should be used unless there's a reason why not - and the only reason why not is if the radio link broke down on the use take.
This is a lovely list of the requirements of the dedicated film luddite who's come up with a spec list based on nothing more than the fact that it's difficult to meet. It's not very practical.
#18 Mike Brennan
Mike Brennan
  • 581 posts
Posted 14 June 2008 - 06:27 PM
Here here to Keiths post!
Fuji tried a "ND filter" (my description) on neigbouring pixels last year in still cameras and a DPreview exhaust test indicated it wasn't a success.
Obviously those shooting docs will have a different wish list than those shooting drama.
But both genres would like as much control of depth of field as possible.
By stipulating a 65mm sensor one is limiting control of depth of field on one direction whereas 2/3 inch limits it in the other.
Ultimate control of depth of field (in theory) is most likely to come from a camera with an interchangeable or adjustable sensor, say from 2/3 inch to 65mm. the challange is to do this and still keep a common texture resolution noise signature ect of the image.
Here is a relevant question. What percentage of 35mm dramas regularly shoot T1.5? im not saying that T1.5 on 35mm doesn't have a place it does!
I believe that a 1 1/3 inch sensor with T 1.5 lenses is more practical and would satisy both day to day narrow depth of field requirements (lets say equivelant in 35mm shooting T2.8) but also offer greater scope in achieving deeper depth of field required for docs.
For many applications 2/3 has too much and 35mm too little, what about 1 1/3?
The brave, so called, revolutionary world of new digital cinema cameras is still being tied to the legacy of a sensor size based on achieving acceptable film grain.
I'd love to see a digtial cinema camera design that starts from scratch that is not dependant on integration with existing film lenses.
RED 3ks format is interesting in its size is around 1 1/3 (?) it just needs more res and a set of dedicated lenses :)
Mike Brennan
#19 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 14 June 2008 - 10:02 PM
Please do not quote out of context, which includes truncating quotes. What I said was:
It's one thing to make small numbers of non-linear CMOS sensors with matched characteristics, quite another to make 12 million of them! Or even 2 million or 640 x 480.
Can you answer the obvious question: "If it can be done, then why isn't anybody doing it?"
#20 David Mullen ASC
  • 20072 posts
Posted 14 June 2008 - 10:24 PM
There's a lot to be said for a camera system that can use currently available optics and not need a dedicated line...
As for non-linear response, surely it would be better and probably ultimately simpler perhaps to someday increase the linear range recorded so you can apply whatever gamma curve you want. Color negative film holds about 14 stops of dynamic range so in theory if you could record more than that, let's say 16 stops of range, as a linear signal, you could emulate the 14-stop curved gamma look of film.
One argument I've discovered for an optical viewfinder is when you've got a 90-second boot-up time with the RED, it can be frustrating to grab a powered-down RED camera and quickly set-up a shot, only to find you can't see anything until it's done booting. Film cameras do have the advantage of only drawing power (other than for some accessories) when actually triggered, and don't have to be powered to look through while setting up a shot.
But personally I don't have a problem with the concept of electronic viewfinders, since it's nice to see the signal that will be recorded... just that the reality of electronic viewfinders on the market leave a lot to be desired. Ideally there would be a hybrid approach as Phil mentioned, an optical image and an electronic image, either side by side, or overlaid in some manner, whatever. Of course, you could have an optical viewfinder and a decent onboard HD monitor.
