DIY hand-crank camera?
#1 pbryant
pbryant
  • 2 posts
Posted 14 June 2008 - 11:34 PM
Hi all,
I've always been a tinkerer, and looking through a gallery of old (~1890s) motion picture cameras, I got intrigued by the idea of building my own hand-crank camera.
I'm wondering if anyone on the boards could point me to some books with more detailed specs/blueprints for these classic cameras, or similar resources online?
I know it's an offbeat request, maybe a little (a lot) anachronistic, but I'd really appreciate a nudge in the right direction.
Thanks so much!
Paul
edit: here's a gallery I was looking at, if anyone's interested:
http://digitalfx.tv/.../html/cine.html
Edited by pbryant, 14 June 2008 - 11:37 PM.
#2 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 15 June 2008 - 03:31 PM
Hi- I'd thought about doing that very thing, rehousing a geneva movement from an automax camera into a nice wood box and somehow adding a gear set so I could get 8:1 with a hand crank. So now I have the pieces, including the nikon mount, but need to be retired and have a workshop :) So if you need a 35mm movement and gears....
#3 John Sprung
John Sprung
  • 4635 posts
Posted 18 June 2008 - 12:40 PM
Some resources:
LaVezzi for sprockets:
http://www.lavezzi.c...vezzistore.html
Boston Gear for -- of course -- gears:
http://www.bostongear.com/
You'll want to design around their stock items, just like any engineer building one-off equipment would.
I'd start with a crank about 6" long driving an 8 frame sprocket. Next to the big sprocket on the main shaft, you want a nice big straight cut bull gear driving a pinion gear 8:1 to make a one frame per revolution shaft for your pulldown. Make them nice and big to get out of the way of your sprocket and film path. A pulley to drive the takeup spindle and a 4:1 bevel gear set to drive a balanced two blade shutter complete the main shaft.
For the pulldown, start with a disc and eccentric screw on the one rev per frame shaft. Then two more moving parts, one with the claws on top and a hole for the eccentric screw on the bottom, the other a link from the middle of the claw piece to a fixed point. Or you could go with a single claw piece and a guide slot.
#4 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 18 June 2008 - 01:17 PM
Hello Paul,
This is another Paul. How much pride will you derive from doing it yourself? Do you need to cut and file all of the pieces like some Afghani gun maker or could you strip parts out of other cameras?
Sincerely,
Another Paul
