The "iris blades" will not move when I adjust the aperature ring.
#1 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 16 June 2008 - 07:21 AM
Bought this lens from ebay http://cgi.ebay.de/w...em=330239650631 . It arrived today but when I move the aperature ring the iris blades inside the lens will not move, they are stuck almost wide open.
Seller says that his AC didn´t notice any problems with it the last time they used it.
Since I got it cheap I figured its better to get it fixed then to try to return it.
Anyone know whats wrong and how much it will cost to fix it and perhaps where I should have the work done? I´m located in Sweden so I´d prefer to have the work on it done inside EU (less hassle with customs).
#2 Saul Rodgar
Saul Rodgar
  • 1682 posts
Posted 16 June 2008 - 10:46 AM
I would send it directly to Zeiss in Germany. That can be expensive, you'll get the best service though. They may not work on it since it has the Optex conversion. There is Les Bosher in the UK, he is cheaper and very good. Maybe he could fix that, you can always ask.
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 16 June 2008 - 10:55 AM
I can suppose,
The mechnaism of aperture control broken and can be problem with control pin.
The control pin can be broken or arcuated or lost.
But, can be more complex problme, the problme with iris, the broken blades or lost blades.
You can see of blades inside lens ?
The ring of aperture control turn easy ?
#4 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 16 June 2008 - 11:32 AM
PM Stephen Williams. He's 'da man over there, for questions from folks here.
#5 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 16 June 2008 - 12:21 PM
I can suppose,
I can see all the blades and they are all in the "same" position creating an opening that you usually see when the lens is at T2.4. The aperture ring turns easy and before I looked thru the lens I didn´t suspect any problems with it. When I move the aperture ring to T2.4 and turn it back and forth while looking thru the lens I can see minor movement on a dust particle that sits on one of the blades.
#6 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 16 June 2008 - 12:24 PM
Thanks for all input folks. I sent a mail to Les the moment I found out about the problem but I haven´t received an answer yet. Will PM Stephen Williams.
