lighting tricks...
15 replies to this topic
#1 Maggie Twomey
Maggie Twomey
  • 9 posts
  • New York City
Posted 17 June 2008 - 02:25 PM
Hi All,
Just want to know when shooting interviews, how to make your subject matter appear younger looking (especially when you have to shoot close-ups)? I have used 2 bounced light source and tried to soften the light as much as I can, however it didn't help as much I thought. Eventually I had to digitally enhance them in post-production -- anybody has a better idea? Maybe a china ball?
thanks
M.T
#2 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 17 June 2008 - 03:06 PM
Makeup.
Lighting only gets you so far.
Good Luck,
Ponce de Leon
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 17 June 2008 - 05:56 PM
You should read this month's article in the AC mag about "Sex and the City". He gives some tips. It's mainly a lot of diffusion, more frontal key lighting and plenty of fill.
#4 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 17 June 2008 - 07:30 PM
Read my article on how I like my women soft. I was taught by the old school hollywood gaffers who taught me that the trick to women is to light them soft (and sometimes hard with a spot head on) and from the front with little to no shadow unless you are using hte shadow to divert the viewer. That, eye lights, soft filtration and back light makes women look wonderful at any age.
http://www.bluesky-web.com/soft.html
BTW Sex and th City (the movie) used electronic painting after the fact to soften many of the closeups of the 40+ actors and horse who had to look like they were still in thei thirties for the film.
#5 Maggie Twomey
Maggie Twomey
  • 9 posts
  • New York City
Posted 18 June 2008 - 12:44 PM
[/quote]
I read the article and it's helping a lot. just wondering, instead of placing a flex fill on the floor and use the bounce light, what if I get a kino flow and place it low (pointing at her from a lower angle)? would that work? or is it still too strong?
Also, will a soft filter work?
thanks!
M.T.
#6 boy yniguez
boy yniguez
  • 92 posts
Posted 19 June 2008 - 07:52 PM
thanks!
M.T.
[/quote]
the flexfill would still give a broader therefore softer source than a kino. the strength of the underlight would be varied depending on how much eyebags and bone structure the talent has!
#7 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 20 June 2008 - 12:36 AM
Sure, why not. I am not a fan of kino flos in most situations so would not use it. But that doesn't mean you could not.
#8 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 21 June 2008 - 12:47 AM
...of the 40+ actors and horse...
"horse"?
Edited by Jonathan Bowerbank, 21 June 2008 - 12:47 AM.
#9 Chris Larue
Chris Larue
  • 4 posts
  • Paris - France
Posted 22 June 2008 - 08:07 PM
Soft F/X filter is your new friend ! This is an amazing filter, and with a front soft light, this is an less expensive way of become younger for actresses.
#10 Brian Dzyak
Brian Dzyak
  • 1517 posts
  • Encino, California USA
Posted 22 June 2008 - 09:34 PM
For younger actresses, I place my Chimera just to the side of the lens and maybe about a foot higher. For older actresses with wrinkles, the stand goes in the same place, but I drop the height to just over the lens. Backlight accordingly.
I like the look of a Black ProMist, but never anything heavier than a 1 at most or else it gets a little obvious. 1/4 or 1/2 works fine.
And of course a brilliant Makeup Artist always helps.
The thing to remember is that no matter what you do, an older "talent" is older. We can do a certain number of things to help them look better, but they'll never look 15 again no matter what we do or how much their Personal Publicists complain.
#11 John Sprung
John Sprung
  • 4635 posts
Posted 23 June 2008 - 12:45 PM
Be careful with that light from below -- you don't want the Dracula look.
#12 John Holland
John Holland
  • 2273 posts
  • London England
Posted 23 June 2008 - 01:13 PM
"horse"?
Just read this thread "Horse" Jessica Sarah Parker must be that what it means she makes ugly mules look good . Yuk .
#13 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 23 June 2008 - 02:36 PM
An Obie is an old school trick.
There's a trick I like for this: I take an 8' X 4' sheet of 1" single sided styro and mount the 8' dimension horizontally, white side toward subject. I cut a square hole in the middle big enough for my lens and shade to poke through. Then I set up 4 1KPars to bounce off both sides, top and bottom. The barn doors keep some of the light off of the lens and camera but it still gets pretty damn hot. But, the light is fantastic and the subject is soft, soft, and lovely. The set up is a pain and clumsy to move. I use it mostly for CUs and head shots but it will hold up even with medium body shots.
#14 David Rakoczy
David Rakoczy
  • 1579 posts
  • USA
Posted 23 June 2008 - 02:50 PM
I like that Paul! It is like a Ring-Lite but with a much much larger Source.... very cool.. gonna try that. I also use Softlites (Zips) under lens on the older Folks when they need some smoothing out..
#15 Rick Shepardson
Rick Shepardson
  • 56 posts
Posted 24 June 2008 - 09:40 AM
Hi All,
thanks
M.T
What are you using to bounce the light? I assume you're probably using bead board or something similar. If you're using a more specular bounce, like silver, then try bead board instead. Also, try bouncing from different angles. I find that bouncing some light from below the subject can soften the face tremendously.
As for the camera, what are you shooting on? If it's digital, you could try taking down the detail level of the camera a bit. Or, you could try using a softening filter.
I ran into a similar problem a few months ago. A woman had very "detailed" skin. Make up came in to fix the problem. Unfortunately, they were inexperienced and actually made the problem worse by putting on this nasty blush which only made the problem worse! I was able to rectify the situation by taking down the detail a bit helped out alot. Of course, keep in mind how busy your background will be and how this might effect the rest of the image.
Also, you might want to try using a softening filter on the lens-a very light pro mist or something. Again, consider how this will effect the rest of the image and if the look will be consistant with the rest of the footage.
Good luck and tell us how it turned out.
#16 boy yniguez
boy yniguez
  • 92 posts
Posted 25 June 2008 - 03:47 AM
yup, the ring light is the ultimate erase-all-the wrinkles solution. similar to paul's contraption i usually use a 4x4 styro with with a hole in the middle but use 4x1 tube or 4x2tubes of kino 40 taken out of their housing and assembled into a 4x4 square light on the styro. just gives an alien-look catchlight on the talent's eyes though.
