Adams 64
7 replies to this topic
#1 Art Leal
Art Leal
  • 145 posts
  • New York City
Posted 17 June 2008 - 03:00 PM
I have a few cameras that require the infamous mercury 2.7v battery. I was wondering if anyone has used the Adams64 modification on their camera(s)?
http://www.film.proj...4_new_cams.html
thanks
#2 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 19 June 2008 - 06:45 PM
thanks
Hi Art,
the principal purpose of the adams64 is to convert a 40/160 asa camera to 64asa. If your cameras don't need this but just his light meter battery modification, why not just use zinc-air 1.35 volt batteries? These are cheap and do a fine job in my opinion.
cheers,
Richard
#3 Art Leal
Art Leal
  • 145 posts
  • New York City
Posted 20 June 2008 - 01:01 PM
Hi Richard.
I just tested a Canon 1218 I recently purchased. The exposure was perfect using two Wein Cell batteries.
I have problems with a few cams that use the PX14 (which is 3v alkaline instead of the required 2.7). The dropoff voltage affects the exposure radically and quite quickly. I will look into modifying or rigging a way to use the Weins on these.
Many thanks
Art
#4 Richard Tuohy
Richard Tuohy
  • 482 posts
Posted 20 June 2008 - 10:44 PM
Hi Richard.
Many thanks
Art
Hi Art,
With Px14 cameras, I generally use two of the wien cells and a little piece of tin foil to take up space. I had an old px14 battery once and peeled off the cardboard cover and indeed found that it was two px625 batteries with a metal spacer.
hidyho,
richard
#5 Alessandro Malfatti
Alessandro Malfatti
  • 149 posts
  • Barcelona, Spain
Posted 01 July 2008 - 03:27 PM
Maybe I'm missing the point, but why don't you use two 1.4V hearing aid batteries (And a metal piece, like tin foil, for filler)? I have no idea how long they last until the Voltage drops off, but they're dirt cheap and you get them easily at pharmacies, so it doesn't even matter if you just use one set for two weeks or so. I used one in my Krasnogorsk-3, when the lightmeter was still working, and got an excellent exposure.
#6 Paul Boers
Paul Boers
  • 7 posts
Posted 01 July 2008 - 04:27 PM
Yes, that is correct. Recently I also bought these 1,4 V hearingaid batteries for my Nizo 801M.
With the batterycontrol, they give the same reading as the original PX 625 mallory. Should read to f8, was indeed dead on...
Haven't filmed so far with these new batteries in my Nizo however.
Success !
cheers,
Paul
#7 Art Leal
Art Leal
  • 145 posts
  • New York City
Posted 10 August 2008 - 05:13 PM
Hi Art,
hidyho,
richard
Here are a few clips with two different cameras, same subject, using the Zinc Air then the Wein cells.
Thanks for the help.
#8 Marc Guerriero
Marc Guerriero
  • 44 posts
Posted 10 August 2008 - 09:17 PM
According to Martin Baumgarten's site, and other photographic sites where they talk about using older cameras that required the 1.3x2 or the 2.7, it would appear that for every .05 volt extra you have, if your camera uses only one of the button batteries, or .1 volt extra you have if your camera uses two of the button batteries, that would make it underexposed by 1/2 stop. Maybe it would be a good idea to have a voltage meter so that you could measure the voltage of these batteries as the voltage drops off through usage. So if you are using three volts instead of 2.7, that would mean that your light meter is underexposing by 1 1/2 stops. That's my deduction anyway. Feel free to debunk me anyone.
