Problems connecting XL2
15 replies to this topic
#1 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 June 2008 - 02:00 AM
Hi!
Trying to connect XL2 to capture some footage to FCP.
Connecting through FireWire (4-pin in camera to 6-pin in Mac). The problem is - mac (10.5.2) doesn't see the camera.
When going to FCP (6.0.2) to capture files, it says that external Apple Firewire PAL (720x576) device is not connected; whe clicking 'log and capture' - "unable to initialize video deck".
Please note that this is the first time the XL2 is connected to this particular MacBook.
What is the problem and how to solve it?
Thanks a lot in advance!
Edgar.
#2 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 June 2008 - 03:39 AM
Weirdly the problem has stayed on Windos with Adobe Premiere as well - PC just doesn't see the camera.
#3 Ollie Bartlett
Ollie Bartlett
  • 88 posts
  • Bristol, UK
Posted 20 June 2008 - 06:22 AM
I know it sounds silly but have you tried using another firewire cable? youve probably done tyhis already but it might be the cause of all your problems.
Ollie
#4 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 June 2008 - 06:23 AM
Ollie
Thanks, Ollie, but I have.
#5 Ollie Bartlett
Ollie Bartlett
  • 88 posts
  • Bristol, UK
Posted 20 June 2008 - 06:30 AM
wow... speedy response.
I usually have the same problem whenever i connect my XL2 to an avid system for the first time. With that its a process of first allocating the imput port and then selecting OHCI via firewire. Now i think about it i really dont know what that means or why i do it... its just what i was taught without being given a reason for why im doing it.
Sorry im not being any help whatsoever :unsure:
It might be worth reposting the same question down in the editors section of the forums.
Good luck mate,
Ollie
#6 Mike Washlesky
Mike Washlesky
  • 194 posts
  • Austin,TX
Posted 20 June 2008 - 09:28 AM
Hi!
Edgar.
Do you have an external hard drive connected? I have run into this problem frequently with specifically Canon cameras and LaCie hard drives. For some reason, when a LaCie ( I have the big Disk Extreme), FCP wont recognize the camera and you cant import video. Both Apple, Canon, and LaCie blame each other for this problem. There's no way to fix that I know of, except to import to a different make drive, or import to your internal hard drive then migrate to the external. I know its a pain, but its the only way we've worked around it on a doc I have been working on for the past year. The Director contacted all parties, and received really no help at all. Just finger pointing.
#7 Harry Christensen
Harry Christensen
  • 6 posts
Posted 20 June 2008 - 09:55 AM
This problem isn't exclusive to lacie drives, I have had the same issues with my maxtor externals too. My work around is to get a USB 2.0 hub and hook my external drives up through that. My mac then recognizes the camera and all is good. I suspect that the issue is with canon's software but as you said nobody wants to own up or fix it. Both my lacie and maxtor drives have both interfaces, though I would prefer to use my lacie firewire 800 it just won't happen if I need to import with my camera. I guess it is more incentive to get a deck and stop using my camera as a deck.
#8 Mike Washlesky
Mike Washlesky
  • 194 posts
  • Austin,TX
Posted 20 June 2008 - 10:08 AM
Wow, didnt realize it was a problem with Maxtor's as well. It is pretty annoying to have to use such work arounds.
#9 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 20 June 2008 - 12:31 PM
Is the camera in VCR mode? ;) he he
In FCP did you try refreshing A/V devices? Perhaps then FCP will recognize it.
I captured some stuff from an XL2 a couple weeks ago without any problems, and this one is a new one to me. I've only heard of issues when shooting free run time code on the XL2.
#10 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 June 2008 - 01:20 PM
I don't.
But thanks anyway!
#11 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 June 2008 - 01:22 PM
Did lots of times - doesn't help.
What I don't understand - Windows doesn't see the camera as well - it doesn't even show that annoying yellow bubble with 'new device' message.
Edited by Edgar Dubrovskiy, 20 June 2008 - 01:22 PM.
#12 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 21 June 2008 - 10:12 AM
UPDATE and SOULUTION.
Basically, bought a third wire (golden (!) 6-pin to 4-pin Firewire). And it worked.
Thanks a lot!
#13 Mike Washlesky
Mike Washlesky
  • 194 posts
  • Austin,TX
Posted 23 June 2008 - 09:53 AM
Thanks a lot!
Glad you got it working. That can be soooo frustrating sometimes..
#14 Taylor Genovese
Taylor Genovese
  • 14 posts
  • Tucson, AZ, USA
Posted 25 November 2008 - 06:29 PM
Thanks a lot!
Could you give me the link to what kind of firewire cable you bought? I've been having this same problem and I have a feeling it's the firewire cable.
#15 Steve McBride
Steve McBride
  • 239 posts
  • New York, NY
Posted 27 November 2008 - 04:45 PM
Make sure that you connect and turn your camera to VCR before you open up FCP. If you open up FCP and then turn on the camera, FCP will not recognize it.
#16 Evan Pierre
Evan Pierre
Posted 05 December 2008 - 04:48 AM
Oh wow, that is quite scary that you are having this trouble with both maxtor and lacie drives. Our schools brand new imacs, each with 2tb of G-Raid external hard drives have the EXACT same problem.
I am going to try that USB hub idea, thanks!
