Telecine transfer - Negative?
#1 Dan Thompson
Dan Thompson
Posted 22 June 2008 - 11:57 AM
Excuse the newbie question, but I have just processed some 16mm film and now have a print and negative.
Once I've shot some more film I intend to get a TK transfer onto DV.
Will it be best for the telecine transfer to be done using the original negatives or the print?
Reason being I have played the print a few times and there are a few scratches on the film. Basically I would like to know the pros and cons of using the negative for telecine transfer.
Thanks for your help!
#2 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 22 June 2008 - 03:18 PM
Negative. The only con is the wear and tear of running it through the scanner, and you'll never do that more than 3 or 4 times. The print is already one generation removed from what you shot.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 22 June 2008 - 03:33 PM
A print has far less information as it's higher contrast. Transfer the negative on a good telecine.
Stephen
#4 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 23 June 2008 - 03:42 AM
A decent post house or lab will have well maintained film movements that won't grind up your negs. Projectors are crueler to prints than good telecine/scan movements are to negatives.
#5 Dan Thompson
Dan Thompson
Posted 24 June 2008 - 03:24 AM
Thanks guys. That's confirmed what I thought in the first place!
