Typical Shooting Ratios?
19 replies to this topic
#1 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 27 June 2008 - 11:48 AM
What is the typical ratios when using film. I've seen some threads in the past but can't seem to locate any. I'm doing a short this summer and am entertaining doing in on 16mm or Super8. The short will be about 10 minutes. I did come calculations using a 5:1 ration and my costs to get it on the computer (develop, telecine, stock, etc) will be around $1200 for 2000' of B&W negative. That of course doesn't include the cost of getting or renting a camera.
Is 5:1 too much, too little or just right?
#2 Chance Shirley
Chance Shirley
  • 256 posts
Posted 27 June 2008 - 11:57 AM
Depends on your style of shooting and the nature of the movie you're making. I've heard of well-planned features with a 1.5:1 ratio, and documentary ratios can obviously be very high -- 60:1, 70:1, 200:1, etc.
I'm around 6:1 on my current feature. I was hoping for 4:1 but missed that mark due to some complex (for me, at least) shots and poor planning.
#3 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 27 June 2008 - 12:04 PM
It's an adaption of a Poe short, so hopefully my actors and actress don't require 200:1!?!!! :blink:
Also, the camera won't be moving at all. All shots will be on a tripod. Inspired by Ozu's films. Since the camera wont be moving that will cut down a bit on the ratio a bit I think.
BTW: Chance, I ordered the DVD used of Ebay. Should be her soon! P.S. Your mailbox is full so I couldn't PM that to you!
Edited by Jamie Lewis, 27 June 2008 - 12:05 PM.
#4 David Mullen ASC
Posted 27 June 2008 - 12:20 PM
The lowest I've ever managed for a feature is 7:1, most of my low-budget features were 10:1, nowadays, it's 20:1 -- for film. For digital, it is even higher. I'd say that 5:1 is the lowest you should ever plan on.
10:1 has the advantage of making calculations easier -- i.e. 100-page script = 100,000' of 35mm stock (rounding a 1000' mag down to 10-minutes).
#5 Tim Terner
Tim Terner
  • 340 posts
  • Prague, CZ
Posted 27 June 2008 - 12:27 PM
20 ;1, And thats with recently, I suppose, A list actors. Why is digital higher David ?
#6 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 27 June 2008 - 12:37 PM
I've done 3:1-12:1 before, tending to find myself around 5:1, but that is with pulling a lot of tricks and special cut-aways to reduce film used. (how many shots of a truck driving down a road do you need?)
#7 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 27 June 2008 - 12:45 PM
So for a 10 minute script I should be looking for round 100 minutes/4000'ish of film? :blink:
Edited by Jamie Lewis, 27 June 2008 - 12:45 PM.
#8 John Sprung
John Sprung
  • 4635 posts
Posted 27 June 2008 - 12:49 PM
The cost of shooting one more take on film is more than on digital, so people tend to let the ratio drift higher.
#9 Evan Winter
Evan Winter
  • 202 posts
Posted 27 June 2008 - 01:02 PM
This doesn't directly help the original poster but it might be interesting. On music videos I shoot an average of 25:1 and I'm pretty sure that's a really low ratio for most Promo directors.
Evan W.
#10 Matthew W. Phillips
Matthew W. Phillips
  • 1792 posts
Posted 27 June 2008 - 01:11 PM
I think another consideration that no one has mentioned is whether the film is dialog heavy or not and whether you're doing sync sound vs. scratch track. If you are doing a short that is "short" on dialog, you should have a much lower shooting ratio than if your movie is dialog heavy...unless you plan on replacing most of your dialog via ADR. It is reasonable to have 4:1 if well rehearsed, little dialog, or using pretty much all ADR.
The sound issue has been most of my problem, personally, for eating up the takes. Also, sophisticated slating takes a lot of time.
#11 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 27 June 2008 - 01:14 PM
My current production has a shooting ratio of 0:1.
#12 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 27 June 2008 - 01:18 PM
There isn't much dialogue that isn't a voice over, but some. There is one long take that I want to do but it can actually be done in two takes that will lessen the burden on the female lead.
Edited by Jamie Lewis, 27 June 2008 - 01:19 PM.
#13 David Mullen ASC
Posted 27 June 2008 - 01:24 PM
If you're not doing a lot of traditional dialogue coverage, you should get by with a 5:1 ratio unless your single master takes, ala Ozu, run long and you shoot a couple of them. That can also burn up film because without coverage, you need to get it right in the single set-up. So rehearse, rehearse, rehearse...
Also, it depends on if your 10-page script is really a 10-minute movie. I shot a scene recently that was one page long but the actor managed to take up four minutes acting it out...
#14 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 27 June 2008 - 01:33 PM
Yeah, it's a seven page script but from past projects I know my writing usually runs long so I guestimated 10 minutes actual screen time. And like you suggested, there will be rehearsals which I've never done more than the night before a shoot.
#15 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 27 June 2008 - 01:50 PM
Just described the feature I'm working on. Dialog-light, and what there is happens to be in an environment where sync dialog is impractical (back of an open pickup truck) so ADR will be the key to it.
#16 K Borowski
K Borowski
  • 3905 posts
Posted 27 June 2008 - 03:34 PM
Mine too!
Keepin in mind Paul, that if you have zero at the other end of the ratio you're going to run into non-real numbers, infinity, and a tear in the fabric of the space-time continuum, so be careful ;)
#17 K Borowski
K Borowski
  • 3905 posts
Posted 27 June 2008 - 03:35 PM
Billy Bob Thorton?
#18 Deepak Bajracharya
Deepak Bajracharya
  • 92 posts
  • Nepal
Posted 27 June 2008 - 06:45 PM
Namaste,
3:1 for my recent short movie, 6min 45sec duration in super 16mm format, not more than 5:1 for the full length features.
With best regards,
#19 John Sprung
John Sprung
  • 4635 posts
Posted 27 June 2008 - 07:18 PM
Consider casting someone with stage experience. They're accustomed to knowing the whole damn show at once, and running it all the way thru. Pizzes 'em off sometimes if a director keeps cutting them in the middle of a scene. Once they get rolling, there's something unsettling about having to put on the mental brakes all the time.
#20 David Mullen ASC
Posted 27 June 2008 - 08:11 PM
Billy Bob Thorton?
Never! His deliveries are usually pretty crisp and snappy, not drawn out.
