Making a French Flag
12 replies to this topic
#1 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 27 June 2008 - 11:59 AM
I began looking for the material that the french flags are made out of on filmtools.com http://www.filmtools...amfrenflag.html. I found that aquarium stores sell it, as well as a few places online, its about 5-10 dollars a foot comes in 1/2 inch and 3/4 inch
http://www.drsfoster...e=12-55321098-2
Also I have a plan to buy a pipe cutter and modify it so that it does not cut but clamps to the camera rods, mini cardellini clamps are about $50 dollars vs the 10 dollar pipe cutter.
http://www.buy.com/p...1/90140336.html
Ill post some pictures when I finish.
#2 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 27 June 2008 - 07:27 PM
That sounds cool but if you're making the clamp and arm are you also buying the $18.00 flag?
Granted, making everything else still comes in less expensively than $80.00 for the whole thing
but the flag by itself is as the site says an 8" X 13" piece of plastic. At that point you probably could buy
a couple of pieces of plastic or some other material, cut them to suit you and paint everything black or
whatever color you want.
#3 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 28 June 2008 - 12:11 AM
Another AC I work with has some plastic that has a metal sheet in between the pieces, good sturdy and not to heavy, I think I'll use some of that. I think it might already be black.
#4 Chris Keth
Posted 28 June 2008 - 12:38 AM
I would stick with attaching the arm to a No.2. The idea for a clamp to go on rods is a good one but it's not very adaptable. There are a lot of different places you might want to put a frenchie other than on rods.
#5 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 28 June 2008 - 12:00 PM
A No.2 grip clip? My first frenchie was made with a desk lamps bendy tubing, and a grip clip. I suppose your right about the adaptable features of a pipe clamp, grip clip is cheaper also
what do you think a good length is for the arm? I suppose I can always carry extra pieces to adjust it.
#6 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 28 June 2008 - 05:22 PM
Aren't we still calling them freedom flags?
This is precisely the kind of stuff that a MIG welder from Home Despot is good for.
#7 Chris Keth
Posted 29 June 2008 - 03:01 AM
I would get a couple feet of arm to work with. I think 16 or 18 inches will generally be the length you'll want.
If you go with the No. 2 solution, line the jaws with tennis raquet grip tape. It will make it clamp much more securely to rods when you need to do it that way.
#8 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 08 July 2008 - 04:02 PM
The stuff you liked to from the "Dr." site are actually snap together coolant fittings. Instead of retail, try an industrial supply like MSC (Manhattan Supply Co), Graingers, or McMaster-Carr, www.mcmaster.com. The first and last company I listed will ship items to anyone.
#9 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 08 July 2008 - 04:43 PM
Already bought some from fosters, probably would have been cheaper at mcmasters, thanks for the info.
#10 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 13 July 2008 - 12:06 AM
http://www.coloradoplastics.com/ is going to cut me a black ABS plastic 9x11 sheet, for 10 dollars. Right now I am using a piece of FRP panel ( the fiber glass board found in many budget shower installations. ) I thought about spray painting it black, but by the time I buy the paint and the primer, its going to cost the same as the ABS plastic, which is a stronger material anyways, and is already black.
How thick is a standard flag 1/8th? 3/32nds? , Ill probably go with 3/32nds.
I'll have some pictures up by the beginning of next week.
I am coming in about 50% of the cost of a store bought french flag.
$10 dollars for 9x11 sheet
$1 misc nuts bolts
$2 grip clip
$26 Loc Line/Adjustable Arm
Jason Anderson
#11 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 15 July 2008 - 12:20 AM
Finished the French flag.
ended up using a .1 inch piece of ABS plastic, very strong at that thickness.
Detailed steps on Instructables.
http://www.instructa...g-Freedom-Flag/
#12 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 16 July 2008 - 01:37 AM
Just wondering if the thickness really matters? Are you worried about it holding up strength-wise, or light being able to permeate it?
My family owns a plastic company on the east coast, too bad I read this post now....though it does give me ideas to make some funky stuff of my own.
#13 Jason Anderson
Jason Anderson
  • 75 posts
  • Denver, Co
Posted 16 July 2008 - 02:20 AM
even the thinnest ABS black sheet does not allow light through, yeah it was mostly for strength and then secondly weight.
Well thats handy that your folks have a plastic company! Let us know what you come up with.
