Kino Tubes
#1 anthony derose
anthony derose
  • 49 posts
  • NYC
Posted 28 June 2008 - 05:09 PM
I did some electric work on a few short projects over the last few weeks. We were working with some kino's and other sources. I noticed that both DP's when switching to daylight tubes in the kino would want one 32k bulb to add some warmth. I know this is all preference on how you want your look to be, but do most add that warmth? I've worked with all daylight tubes before and it looks fine to me.
#2 timHealy
timHealy
  • 1262 posts
Posted 28 June 2008 - 06:00 PM
Mixing tubes is simply a creative choice.
Best
Tim
#3 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 29 June 2008 - 04:57 PM
Like Tim said, it's all creative choice. Some people wrap a kino in 1/8 cto for a similar effect.
There are many roads to arrive at the same destination.
#4 Chris Keth
Posted 29 June 2008 - 09:07 PM
It's pretty common. I work with a DP who likes all of our kinos kept half-and-half. That gets through most situations and if he wants full output warmer or cooler than tubes are swapped out.
#5 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 03 July 2008 - 04:40 AM
Known round this part of the world as a "mixed grill"
as in....
Gimme a 4' quad chequebook with a mixed grill
4 'kino 4 bank set horizontally with half daylight and half tungsten tubes....
jb
#6 David Mullen ASC
Posted 03 July 2008 - 11:43 AM
I don't like to do that because I often turn off one tube or turn it back on to control the output level, so if one or two of the tubes are a different color, then the overall color changes if I have three tubes on versus four tubes on.
#7 Nadav Hekselman
Nadav Hekselman
  • 68 posts
Posted 03 July 2008 - 04:57 PM
Im with David.
You have more control when all your tubes are the same.
After you know the amount of light you need you can always change texture or color using gels.. if you know you are going to use gels, just keep in mind that you need the kino's a little brighter since the gell will take out some of the light.
