Does anyone know the formula for using 2/3 lens on 1/2 cdd?
19 replies to this topic
#1 Jason Davenport
Jason Davenport
  • 21 posts
  • Dallas, TX
Posted 11 July 2008 - 01:17 PM
Is there a formula for finding out the new lens MM's when putting a 2/3 lens on a 1/2 censor. Yes, it's for the new EX-3. 2/3 is 11mm diagonal and the 1/2 is 8mm, if this is any help.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 11 July 2008 - 01:25 PM
This should be moved to one of the video folders.
#3 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 11 July 2008 - 02:44 PM
Use your high school algebra to derive the formula.
#4 Mark August SOC
Mark August SOC
  • 30 posts
  • Hollywood, California
Posted 11 July 2008 - 03:40 PM
The Sony EX3 is not out and still in beta tesing before release. If using a 2/3-inch type lenses with the EX3 camcorder, the Fujinon ACm-21 lens mount adapter must be used. Then your 2/3 inch lens will mount to the camera. Ref. www.sony.com/xdcamex
#5 Chris Keth
Posted 11 July 2008 - 03:58 PM
Recite this sentence:
The focal length of a lens does not change when you put it on a different size sensor or piece of film.
#6 Jason Davenport
Jason Davenport
  • 21 posts
  • Dallas, TX
Posted 12 July 2008 - 01:07 AM
I beg to differ unless the adapter in question repositions the the focal plane to the correct size. Correct?
Recite this sentence..
"The zoom ratio is stated as being for instance 6:1 this means that the longest focal length is six times that of the shortest. The usual way of describing a zoom lens is by the format size, zoom ratio and the shortest and longest focal lengths, i.e. 2/3," 6:1, 12.5mm to 75mm. Again, great care must be taken in establishing both the camera and the lens format. The lens just described would have those focal lengths on a 2/3" camera but a range of 8mm to 48mm on a 1/2" camera. Similarly a lens giving the same performance on a 1/2" camera would be a 1/2," 6:1, 8mm to 48mm."
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 12 July 2008 - 03:15 AM
Too much marketing hype is confusing you here. The angle of view of the lens will change but the focal length is always the same.
Stephen
#8 Chris Keth
Posted 12 July 2008 - 04:10 AM
You're buying into a lot of "effective focal length" bullshit. The focal length of a lens is a physical attribute of the lens. It does not know what it is projecting an image on so how could be possibly change focal length when you put it in front of any given format of sensor or film.
As Stephen says, you are considering the angle of view of the lens. That does change because you are using more or less of a lens' coverage by using the lens on various formats.
Take this example:
A 120mm lens on an 8x10 camera is a very wide lens. That camera/lens pair would have an horizontal angular field of view of 93 degrees.
Put that same 120mm lens on a 35mm camera (or, alternately, think of it as masking everything except a 24mmx36mm rectangle of that 8x10 groundglass) and that camera/lens pair would have an horizontal angular field of view of 17 degrees.
Notice that the focal length remained constant even though the same lens functioned as a wide lens than as a long lens.
#9 Andrew McCarrick
Andrew McCarrick
  • 196 posts
  • Atlantic City, New Jersey, USA
Posted 12 July 2008 - 09:54 AM
I think the question should really be interpreted as what 1/2" focal length will the 2/3" lens create to match the field of view. 50mm 2/3" won't have to the same field of view as a 1/2" 50mm lens, so therefore what 2/3" lens will create a field of view that matches what ever lens in the 1/2" line-up.
Edited by Andrew McCarrick, 12 July 2008 - 09:57 AM.
#10 Andrew McCarrick
Andrew McCarrick
  • 196 posts
Posted 12 July 2008 - 10:02 AM
If I figured this out right you should multiple the Focal Length of the 1/2" lens by 1.375 to get the 2/3" focal length to achieve the same field of view. Or is it the inverse of that (.72)?
Edited by Andrew McCarrick, 12 July 2008 - 10:04 AM.
#11 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 12 July 2008 - 02:43 PM
If you put the 2'3" lens on the 1/2" camera, the focal length will remain the same.
A 6:1, 12.5mm to 75mm lens will still be a 6:1, 12.5mm to 75mm lens.
#12 Chris Keth
Posted 12 July 2008 - 05:29 PM
Andrew, you've stated it correctly. If you have a focal length on a 1/2 inch camera and want to know what focal length will look the same on a 2/3 inch camera, you would multiply the known focal length by 1.375.
You would multiply by .72 to go the other way (know a focal length on 2/3" and want to know a focal length that will look the same on 1/2")
I will say it once again for posterity. This math above is to find equal fields of view. The focal length of each lens never changes simply from using it on a different format.
#13 Jason Davenport
Jason Davenport
  • 21 posts
  • Dallas, TX
Posted 12 July 2008 - 10:09 PM
Thanks, thats exactly what I was looking to find. "multiply the known focal length by 1.375."
#14 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 12 July 2008 - 11:47 PM
I got slightly different results, 1.32 and .75 depending on direction. I double checked but maybe I made the same mistake twice.
How did you do the math?
#15 Andrew McCarrick
Andrew McCarrick
  • 196 posts
Posted 13 July 2008 - 01:39 AM
From what I found it said 2/3" is 11mm diagonal and 1/2" is 8mm diagonal, so I divided 11 by 8 and got 1.375
#16 Tim O'Connor
Tim O'Connor
  • 860 posts
Posted 13 July 2008 - 01:47 AM
Cool, thank you.
#17 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 13 July 2008 - 03:05 AM
Cool, thank you.
I dont see how this helps in any way, if you use a lens designed for a 1/2 inch sensor it's milimeter markings will exactly mark the milimeter markings of the lens designed for the 2/3 inch sensor.
Stephen
#18 Chris Keth
Posted 13 July 2008 - 09:47 AM
I didn't. I took the figures stated as correct. It was the concept I had issue with.
All you do to get the two factors is divide 8 by 11 and then use 11 by 8 to go the other way.
#19 Tim O'Connor
Tim O'Connor
  • 860 posts
Posted 13 July 2008 - 12:43 PM
I think that this clarifies an issue that confuses a lot of people and drives a lot of other people crazy because
they are right when they say that 'focal length is focal length' no matter what. The people who are confused probably
haven't had as much experience in different formats and so they find out that a 50mm lens seems to give a different
sized image in two different formats and focus on the focal length.
This is a useful formula for people who want to know "what lens do you use in X format to get
the closeup that a 100mm would give you in Y format?"
I should have quoted Andrew, Chris, as I was asking about his original math. I see what I did now though, thanks everybody.
#20 Glen Alexander
Glen Alexander
Posted 13 July 2008 - 01:44 PM
why don't you use the standard lens maker equation?
1/f = 1/d1 +1/d2
M=-d2/d1
