lighting for 60fps varicam
#1 hennbot
hennbot
  • 8 posts
Posted 17 July 2008 - 08:48 PM
When lighting for Varicam shooting overcranked footage at 60fps do you need to add light to compensate for the frame rate change? Should I light the scene with the camera in the 60fps mode for monitoring purposes?
Thanks!
#2 John Ealer
John Ealer
  • 187 posts
Posted 17 July 2008 - 09:07 PM
Thanks!
Yes, and of course with the shutter set to your desired angle / speed as well.
J
#3 Ollie Bartlett
Ollie Bartlett
  • 88 posts
  • Bristol, UK
Posted 23 July 2008 - 04:58 PM
What would be the necessary compensation for this? Am i right in thinking that because you need to half the shutter speed, ie change 1/60th to 1/120th, you would need to double the light and so overlight by 1 full stop?
Ollie
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 24 July 2008 - 09:36 AM
It is actually quite simple as you can see the effect directly on the monitor. Fast frame rate means that each frame is exposed to light for less time and therefore less bright. The difference between 24p and 60p is 1.5 stops. No need to adjust the shutter.
#5 Chris Keth
Posted 27 July 2008 - 07:55 PM
You don't HAVE to adjust the shutter but I find that most people that overcrank the varicam prefer to apply a bit of a shutter change for a bit crisper image.
