SRW-1 recorder
#1 Scott Dolan
Scott Dolan
  • 36 posts
Posted 20 July 2008 - 05:14 AM
Hi all,
This is my first post on cinematography.com.
I'm an Australian 1st AC based in Byron Bay NSW.
Looks like there's quite a few knowledgeable camera people on here so I'm looking forward to some quality posts.
I've been having an issue with the SRW-1 recorder when used with Genesis and F23 camera's.
I often get an error on the recorder "#0010: Telefile full" which I know refers to the fact that the telefile memory of the recorder is full, however I'm not sure how to delete the existing memory in the field (after 70 files it is full). Alternatively, I just need to be able to switch off the error message from showing in the viewfinder but still have VF Display.
Any ideas?
I know this error message does not affect recording in any way or shape, but its just annoying for the operator to have "VTR WARNING" flashing in the viewfinder if he or she wishes to monitor VF Display while shooting.
Cheers
#2 Christopher Santucci
  • 124 posts
  • Buffalo, New York
Posted 20 July 2008 - 09:48 AM
The user's manual should be available online:
http://www.google.co...G=Google Search
#3 Scott Dolan
Scott Dolan
  • 36 posts
Posted 20 July 2008 - 07:24 PM
The manual is the first place I looked. But unfortunately doesn't help.
Thanks anyway.
#4 Mark August SOC
Mark August SOC
  • 30 posts
  • Hollywood, California
Posted 21 July 2008 - 10:30 AM
Thanks anyway.
Scott,
Is this a new HDCAM SR Tape? Here is a step-by-step answer to your question. The tape which has a full "Telefile" needs to be in the SRW1 deck and turned on from the camera or on the SRPC.
On the remote push "HOME" plus "SYSTEM" at the same time.
This will bring you into the "DIAGNOSIS" page
using the toggal/dial to the "TELEFILE" page and select enter
select the "FORMAT" page and push enter
This will bring you to a page which state's "Format Telefile?" Press [Func] + [Enter] to Format.
This will clear your Telefile inside the HDCAM SR Tape which is full of data. As for the flashing VTR warning in your viewfinder this will stop. You can also set up what warning you what to see or not see in the Operation menu on both the Genesis and F23. You can call on your Rental house on this. You should not have seen this Telefile full if you have a new tape.
Hope this has helped and your shoot goes well.
All the best,
Mark August
Panavision Hollywood, CA
#5 Scott Dolan
Scott Dolan
  • 36 posts
Posted 23 July 2008 - 04:37 AM
Scott,
All the best,
Mark August
Perfect!
Thank you mate.
That's exactly what I was looking for.
#6 Matt Workman
Matt Workman
  • 421 posts
  • NYC
Posted 23 July 2008 - 02:40 PM
wow, I have a lot to learn about the F23/Genesis. I thought the F900/Varicam menu was intense...
Glad everything worked out for you though. :lol:
