super 35
#1 pushpa
pushpa
  • 11 posts
Posted 21 July 2008 - 10:11 AM
hi to everyone who r reading this lines...
i have a little bit of confusion with super 35 and cinemascope...in wikipedia it is given that super 35 mm uses the space which is normally reserved for analog soundtrack...but my teacher told me that the choice of lenses of super 35 mm is more because of spherical type lenses so only they are using this format...
can anyone out there help me...??? :unsure:
thank you... :rolleyes:
#2 timHealy
timHealy
  • 1262 posts
Posted 21 July 2008 - 05:05 PM
I'm not sure about cinemascope but many utilize super 35 and normal spherical lenses and cropping to 2.35 frame as an alternative to using anamorphic lenses.
Film is so good these days not many people notice except maybe when you see flares. I'm sure there are other ways too.
Best
Tim
#3 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 22 July 2008 - 09:10 AM
Simple, Cinemascope requires Anamorphic lenses, but is onto the normal academy film frame. This allows for optical print-outs simpler. Super35 uses the full-frame rather than the academy frame, utilizing the side area normally used by the soundtrack. This is more complex to print, but can utilize spherical lenses.
#4 David Mullen ASC
  • 20069 posts
Posted 22 July 2008 - 09:30 AM
Super-35 uses the first box (A) with spherical lenses but you crop way, way down for 2.40, then convert the cropped portion in post to the fourth box (D), for CinemaScope (anamorphic) with a 2X image squeeze. Shooting with anamorphic lenses uses diagram D -- as you can see, even though you don't use the soundtrack portion on the left, overall you use more negative area than Super-35 (Full Aperture) cropped in half to get 2.40.
#5 pushpa
pushpa
  • 11 posts
Posted 22 July 2008 - 09:13 PM
thank you David Mullen for ur reply...
i saw ur works on ur website and they are awesome...i wish i could do photography like that one day...
cheers...
Edited by pushpa, 22 July 2008 - 09:14 PM.
