Quaternion math mean anything to you ? if so then I'd like some advice
7 replies to this topic
#1 Chris Millar
Chris Millar
  • 1642 posts
Posted 05 August 2008 - 12:54 AM
I would like to learn more about the math involved in both 3D and 2D graphics and how it is made into logic that PC's can handle.
First concentrating on the 2D - image analysis and manipulating for instance, is this all matrices/linear algebra ? Basically I'd like to be able to have a conceptual grasp on how image/moving image data is represented mathematically and then how to manipulate it.
3D is also a fascination, specifically the representation/sampling/modeling of real life in computers - spatial/temporal info and physics/kinematics for instance - for use in robotics/moco and the fusion between this and CGI - is this all calculus, and coordinate geometry ?
What topics am I really looking into ?
What have I missed out ?
I'm pretty good self learning outside of a classroom, any recommended books ?
thanks,
Chris
#2 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 05 August 2008 - 09:00 AM
Hello Chris,
This might not be the most productive forum for your questions. While we've got some remarkably sharp people who post here, the emphasis here is in cinematography and videography. Have you had difficulty finding graphics-math folks in the various and abundant computer forums?
#3 Candice Cardasis
Candice Cardasis
  • 2 posts
Posted 05 August 2008 - 02:06 PM
Chris,
Get yourself to SIGGRAPH 08 this year. Seriously. You're bound to find something.
http://www.siggraph.org/s2008/
-C.
#4 indiefilmgal
indiefilmgal
  • 5 posts
Posted 05 August 2008 - 02:30 PM
yea those are great
#5 Phil Rhodes
  • 12161 posts
Posted 05 August 2008 - 03:46 PM
indiefilmgal - do you read at the adult level?
Is there something unclear to you about the real-name instructions given on signing up?
#6 Glen Alexander
Glen Alexander
Posted 05 August 2008 - 07:36 PM
look at the nvidia manual, it is all pixel based using basic geometry using the GPU fuction calls for speed.
sometimes, it depends on the data and the space.
for speed flatten the 3d space, hide lines and shapes that aren't visible for speed.
no
look into Hilbert space and linear transform matrices and inversion.
quaternion math is only used if you need to a solution where the physics/equations of Hilbert space or rectilinear space break down.
each GPU will utilize differing amounts of pipes, ram, processing of instructions. you need to look at the architecture of the chipset to know why they designed it for opengl, etc. true 3d structures are much tougher to display, rotate, convolve then simple 2d transforms.
head over to www.doom.org
Edited by Glen Alexander, 05 August 2008 - 07:39 PM.
#7 Chris Millar
Chris Millar
  • 1642 posts
Posted 10 August 2008 - 01:47 AM
Hello Chris,
I have posted similar questions in more relevant forums (well, one at least). The reason I posted here regardless is that cinematography and to a lesser extent still photography is the world I plan to apply what I learn.
One relevant application I see directly is video codecs/digital cinema, post effects and also motion control etc..
Glen, looks like you're much further down a path I may wander across or follow directly at some stage - doom.org - I'll have a look
#8 Chris Millar
Chris Millar
  • 1642 posts
Posted 30 August 2008 - 10:20 PM
Hey - what's up with doom.org ?
I get a full stop
<html>
<h1>.</h1>
</html>
you mean .com ?
or is there some sort of restriction to the uninitiated ?
