SPINNING CAMERA EFFECT...HOW TO ACHIEVE THIS???
11 replies to this topic
#1 Daniel Porto
Daniel Porto
  • 201 posts
Posted 14 August 2008 - 09:30 AM
TO ALL,
I was wondering How to achieve a spinning camera effect. To explain myself better I want the camera to stay in the same position but then spin all the way around, so that the image goes upside down and then back to the normal upright position again. This type of shot can be seen in apocalypse now when martin sheen is being thrown to the mud towards the end.
ANY IDEAS ON HOW I CAN ACHIEVE THIS? (the cheap way)
p.s. I am also interested how they achieve this the hollywood way, whoops I meant expensive way :P
#2 Warwick Hempleman
Warwick Hempleman
  • 115 posts
  • Germany
Posted 14 August 2008 - 10:46 AM
The Panatate was one way, now any 3-axis head (remote or manual) will do. You need to center the camera's film plane very carefully in order to have a perfect circle, and not an eccentric or precessing movement. I'm sure other members will have more to add.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 14 August 2008 - 12:48 PM
A rollvision rig. It's a big circle with the camera in the center.
#4 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 15 August 2008 - 01:31 AM
You could build a metal or wooden support framework with a spindle that has a crank handle and a plate welded or bolted to it. Bolt a heavy L shaped bracket to the spindle plate to hold the camera so the axis of the lens in in the exact center of the spindle axis. Counter balance the camera with weights at the top pf the spindle plate so when the camera is mounted on the bracket it will spin on it's axis easily. Then set up the shot and hand crank at the speed you want the camera to spin. A little work but fairly easy to build.
What MIGHT work if you're lazy like me is find (or you may already have one) a motor stand and set it on some apple boxes then shim it till it's square and lock it down. These allow heavy car engine to be turned upside down easily so a movie camera would be a piece of cake. THEN all you gotta do is fabricate an L bracket and counter balance system, bolt the camera to it and BAM you're done. Too easy.
Edited by James Steven Beverly, 15 August 2008 - 01:32 AM.
#5 Evan Pierre
Evan Pierre
Posted 20 August 2008 - 03:41 AM
Wouldn't it be possible and much simpler to do this in post?
Simply set up your frame with enough extra space to allow you to take the image and rotate it 360 degrees without seeing the edges.
Edited by Evan Pierre, 20 August 2008 - 03:42 AM.
#6 Chris Keth
Posted 20 August 2008 - 08:57 AM
It is the simplest way, you're right. Unless you have the money to do it right by going up a format size to have greater resolution to zoom into, the enlargement poses a problem. On a 1.85 frame, it would have to be more than a 50% enlargement to avoid seeing any frame edges.
#7 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 21 August 2008 - 05:07 AM
if people keep doing everything on post, very soon we won't need people, except from the post people...
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 August 2008 - 05:33 AM
Taking that comment further. The 5 minutes a frame rendering time will be off-putting to many.
http://grail.cs.wash...Enhancement.htm
#9 Joe Walker
Joe Walker
  • 82 posts
  • Birmingham, AL
Posted 21 August 2008 - 02:21 PM
That is some truly scary stuff Stephen!
#10 Mark August SOC
Mark August SOC
  • 30 posts
  • Hollywood, California
Posted 22 August 2008 - 10:32 AM
TO ALL,
There are few ways to achieve this effect. We have a rig called the PANATATE. The camera is mounted in the center of a circled camera base with the gear heads turning the camera. It has taken a full day to insure the camera is centered and balanced.
As for cheap, it maybe cheaper to rent the gear needed for your effect than the time (time is money) it would take and re-inventing the wheel (plus the unknown cost)! However, it is fun to try!
The fast and easy way is using the Fasier lens which spins the lens. I have attached a link to the panavision web site which shows the fasier lens in use via a video. See below link.
http://media.panavis...ml/Frazier.html
All the best,
Mark August, S.O.C.
Panavision Hollywood
#11 Matt Irwin
Matt Irwin
  • 389 posts
Posted 25 August 2008 - 03:21 PM
Daniel,
If I'm understanding you correctly, your shot can be accomplished with a Cartoni Lambda head - basically a 3-axis nodal swing head that can be set up to spin the camera on it's optical center by way of a manual steering wheel (like a gear head wheel). I believe there is also a motorized version, but I've only ever seen the manual type in person. I know Clairmont rents them, as do some other places around LA. Don't think it's all that expensive to rent for a couple days.
http://cartoni.com/eng/lambda.html
#12 David Regan
David Regan
  • 218 posts
Posted 25 August 2008 - 11:05 PM
Revolution lens system will do this. I think it's based on the same principle as the Frazier lens system Mark mentioned.
http://www.clairmont...s/rev_lens.html
