PITCH IN ARRI 435 EXTREME
#1 manoj paramahamsa
manoj paramahamsa
  • 13 posts
  • india
Posted 15 August 2008 - 04:25 AM
WHAT FUNCTION DOES THE PITCH IN ARRI 435 SIGNIFIES
#2 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 15 August 2008 - 06:53 PM
Hi-
It adjusts the pitch of the pulldown (you dial it back and forth while the camera is running) so that the filmstock runs through the camera smoother and more quietly. Smooth is good (especially if you're shooting hi-speed) quiet doesn't really matter that much if you're already shooting with a 435! :)
#3 Chris Keth
Posted 15 August 2008 - 08:32 PM
Film can contract and expand in different humidity and temperature comditions. That will cause the perforations to be slightly different distances apart from factory spec. Pitch adjustment adjusts the movement to compensate for this.
#4 manoj paramahamsa
manoj paramahamsa
  • 13 posts
  • india
Posted 16 August 2008 - 09:09 AM
hi thanks for that
and it has five (1-5)adjustment which one i should use to get more stability i don't have issues with sound
and i am shooting in india average temperature will be +/- 30 degree C for that which pitch level should i use
#5 Mike Panczenko
Mike Panczenko
  • 324 posts
  • 2nd Assistant Camera
  • Philadelphia, USA
Posted 16 August 2008 - 10:28 AM
hi thanks for that
The way to determine which setting to use is to roll a few feet and turn the pitch adjustment knob until it is at the quietest setting. There's no set pitch for different conditions that always works. You have to waste a few feet and go by that.
