Hurricane Gustave
7 replies to this topic
#1 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 01 September 2008 - 01:46 PM
Was just catching Weather Channel's coverage of Gustave. The reporters were holding an ordinary mic. Just a little, foam wind filter. No mic barney. Yet, there was no wind noise. Do they do that with software? If so, what's it called?
#2 Adrian Sierkowski
  • 7373 posts
Posted 01 September 2008 - 01:53 PM
Well I'm sure the Foam is acting as a bit of a wind-screen and the fact that it's so close to the reporter's mouth might help out with the S/N ratio to drop out a lot of the wind. If it's a live broadcast I'd doubt there using anything particularly software based. Sadly I have no cable tv to check any of this out on.
Edited by Adrian Sierkowski, 01 September 2008 - 01:53 PM.
#3 Christopher Kennedy Alpiar
  • 47 posts
  • Sound Department
  • Dayton, OH
Posted 01 September 2008 - 02:07 PM
I hate to be the cynic, but is it possibly a well done blue screen?? :-)
#4 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
Posted 01 September 2008 - 02:13 PM
That's freakin' brilliant, man. Just use footage from Katrina and BS/MT your reporters on top, right there in Atlanta. Who'd know or care? It wouldn't cost them a dime.
I'm gonna' marry that Christopher.
#5 Adrian Sierkowski
  • 7373 posts
Posted 01 September 2008 - 02:14 PM
Actually that is pretty brilliant! Problem might be matching the lighting conditions, but if you're good enough. . .
#6 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
Posted 03 September 2008 - 09:48 PM
What about chest mounted lavs with a good foam jacketing of some kind? Those guys had on a rain coat anyway. A couple inches of foam wouldn't be noticed. If you ran 4 lavs at a lower setting then you could gather a lot of voice and reduce the noise plateau. Then run them through a Shark DSP110 each and limit them. When one rumbled it would cut out and the other three would still pick up the cumulative voice. The DSPs have a 2.5 second delay which could chop noises in 2.5 second increments while the others take up the slack. That might do it. I've got one of those DSPs and they kick some serious a** for the money.
#7 Ira Ratner
Ira Ratner
  • 558 posts
  • Coral Springs, Florida
Posted 07 September 2008 - 01:05 PM
There probably WASN'T hardly any wind noise, because as a South Florida resident, believe me:
Anything the TV stations and their on-air personalities can do to hype up the tension of a hurricane, like that wind noise, they would definitely do. So they sure wouldn't do anything to get RID of that noise.
It's their one shot at being famous, important, and noticed--because as a rule, that's all that they live for in the first place.
Who the hell decides to become a METEOROLOGIST? And even worse, someone they just send out to report on this stuff?
Edited by Ira Ratner, 07 September 2008 - 01:08 PM.
#8 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 09 September 2008 - 05:04 PM
A regular vocal-mic has already a windscreen (the round basket-thing on top). If you ad some foam, these mics become rather stormproof, but you have to hold'em close to your sound source.
