DI Stock<=> Postive Stock
#1 devang vyas
devang vyas
  • 1 posts
Posted 11 September 2008 - 03:31 AM
I want to have an understanding regarding the results for a combination of DI Stocks viz Postive Stocks
After recording and processing the DI Neg. is it possible to change the brand of the positive stocks.
If the DI neg is calibrated at a particular DI Studio for a Brand of postive stock is it necessary to recalibrate the same Brand of DI Negative at the same studio if there is a change in the Brand of the Positive Stocks?
Is it necessary to calibrate the different brands of postive stock available with the different brands of DI Negative - including cross combination .
Please comment
Devang
#2 Andrew Koch
Andrew Koch
  • 243 posts
  • Burbank, California
Posted 11 September 2008 - 04:22 AM
By brand of positive stocks, are you referring to Fuji and Kodak? Which positive stocks are you referring to and what do you mean by the DI Negative? Do you mean the raw files once you have scanned the film? What are you referring to by "brand" of DI negative? Are you referring to the color correction software/hardware, or the scanner, or something else?
Also, you need to go to the "My Controls" link toward the top right of the site and change your screenname to you first name, a space, and then your last name, as this is a requirement of this forum
