Workflow questions
#1 Jonathan Burton
Jonathan Burton
  • 22 posts
  • Australia
Posted 11 September 2008 - 06:15 PM
I have just finished a project on HD1080i50 using a sony Z1P. It looks good, but now i am wondering the best way to down convert it and whack it on a DVD. What will give me the best results in terms of res and overall quality? Also what compression format should i use, (I am working on a mac with final cut). Any advice on this would be really helpful, cheers.
#2 Varun Nayar
Varun Nayar
  • 17 posts
  • India
Posted 10 November 2008 - 02:10 AM
well i presume u shot hdv 1080i50 and via the hdv codec or apple prores captured it into fcp mov files. well u can export them as uncompressed files (or DV/DVcam with 16:9 frame size) and use compressor to do a dvd output..it depends on the length of ur footage. u could use the compressor's apple dvd option to either select an mpeg or a h.264 compression. or u could downconvert on the fly from the camera menu itself and go straight to compressor.
#3 Adrian Sierkowski
  • 7366 posts
Posted 10 November 2008 - 02:29 AM
If you're working with DVD studio pro, I would go out uncompressed SD and then either let DVD studio pro do the compression (change all presets in there to multipass, highest, and up the bit-rate as much as you can) or go through compressor with an uncompressed SD file. No need, I don't think, to introduce DV compression and then MPEG2 on top of that. This is my opinion, but I always go HD--->Uncompressed SD--->web/dvd/flash with my stuff. I find i get better results than with DV/DVCPRO. Test with a short clip with a lot of information in it to check . It's always a balancing act.
#4 Adrian Sierkowski
  • 7366 posts
Posted 10 November 2008 - 02:31 AM
