2K DPX Log in Apple Color
#1 Rodrigo Silvestri
Rodrigo Silvestri
  • 39 posts
  • 2nd Assistant Camera
Posted 16 September 2008 - 06:09 PM
Hi. I am a student and I had the opportunity of having a free scan of my first Film short (16mm) on an Arriscan.
This is my previous post:
http://www.cinematog...showtopic=32035
I am now here with my DPXs. I have 3 folders (one for each roll) and each one contains only DPX files. I want to import them to Color, so I can do my Offline master to edit in FCP.
In Color (setup, shots tabs) all the files do not seem to follow an order, and the only way to import them seems to be to grad and drop one by one.
How can I select all the files at once, and put them in Color?
Rodrigo
#2 Rodrigo Silvestri
Rodrigo Silvestri
  • 39 posts
Posted 16 September 2008 - 07:22 PM
I found the problem.
The manual talks about the DPX files as [name].[7digitsnumber].dpx
My files are [7digitsnumber].dpx
So I added the name to the files (using automator, of course), and it works :D
#3 Michael Collier
Michael Collier
  • 1262 posts
Posted 16 September 2008 - 09:21 PM
Glad to see you got it sorted. Another way would be to import them into final cut, arrange them their, then export the XML file, and import that XML into color.
#4 Keith Mottram
Keith Mottram
  • 824 posts
Posted 17 September 2008 - 07:28 AM
Rodrigo
Hi you are going about this the wrong way round, offline then color correct not color correct then offline. you need to use gluetools or aja dpx or bm dpx converter to wrap the dpx into qts then you will probably want to chuck those qts into compressor for offline editing proxies. once you have done your cut you will then relink to your original dpx files and color correct.
keith
#5 Chris Burke
Chris Burke
  • 1723 posts
  • Boston, MA
Posted 17 September 2008 - 04:08 PM
keith
I have used the Black Magic utility, what is it now, Framelink?? Anyway, it worked flawlessly. Simple to use. You definitely need to do what keith has said, its not all that hard. What kind of monitor are you using for the grade?
